intialization in VHDL
amburose
Junior Member level 3
i have problem when i am intialize the value in the entity part...
synthesis and simulation is right ...but real time i got different result from simulation....
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity last is
Port ( a : in std_logic_vector(31 downto 0):=x"FE3A3AB2";
k : in std_logic_vector(31 downto 0):=x"00112233";
clk : in std_logic;
rst : in std_logic;
q: in std_logic_vector(1 downto 0);
d : out std_logic_vector(7 downto 0));
end last;
architecture Behavioral of last is
signal c,d1:std_logic_vector(31 downto 0):=x"00000000";
signal count:integer range 0 to 255:=0;
signal en:std_logic;
begin
process(a,k,c,d1,clk,rst)
begin
if(rst='0') then
d<=x"00";
en<='0';
elsif(clk='1' and clk'event) then
d1<= not(a xnor k );
c(31)<=d1(31);
loop1:for i in 30 downto 0 loop
c(i)<=c(i+1) xor d1(i);
end loop loop1;
case q is
when "00"=> d<=c(31 downto 24);
when "01"=> d<=c(23 downto 16);
when "10"=> d<=c(15 downto 8 );
when "11"=> d<=c(7 downto 0);
when others=> d<=x"00";
end case;
end if;
end process;
end Behavioral;
in the same way i put the value inside the architecture..i got perfect result
ie...
d1<= not(x"FE3A3AB2" xnor x"00112233"); instead of d1<=not(a xnor k);
im using xilinx project navigator 6.3i...
is it software problem........or what else.....
plz its urgent....
Thanks once again hearing from u....
nxtech
Full Member level 5
NO HIDDEN LINKS
I hate to say it but it could be the tool. If you can you need to download the newest version of ISE and then try again. Your code looks fine and its not surprising that your actual results are different from your simulation.
The newer versions of the ISE tool have usually fixed limitations of the earlier releases so give that try and let us know how things work out.
E
    amburose
salma ali bakr
Advanced Member level 3
see with the tool first....
then maybe try to put them in both numerical values in a generic then assign them to a and k...or make constants and assign their values to a and k....you can do that since they aren't changed throughout the program
amir81
Member level 2
did ise send you warnings?
amburose
No warnings......
the code is here...but i got same problem....
library IEEE;
entity last is
Port ( a : in std_logic_vector(31 downto 0);
k : in std_logic_vector(31 downto 0);
clk : in std_logic;
rst : in std_logic;
end last;
begin
begin
if(rst='0') then
d<=x"00";
d1<= not (a xnor k);--not(x"FE3A3AB2" xnor x"00112233");
c(31)<=d1(31);
end loop loop1;
case q is
end case;
end if;
end process;
end Behavioral;
but now web update of 6.3i not available......
is it problem...
Iouri
Advanced Member level 2
In "real" world there is no way to initilize inputs like that, you need to apply the real signals, also
will never work you have to use reset signal to initilize those values. For that simple HDL code tool is NOT a problem
FvM
Super Moderator
Staff member
Bochum, Germany
I don't agree regarding internal signal respectively registers. With most FPGA (for sure with Altera, don't know exactly with Xilinx), registers have a power-on reset state, and it's value is usually inferred from signal initialisation as shown above. It's advisable to have an asychronous reset anyway, but in situations where it isn't available, power-on reset may help.
echo47
Advanced Member level 5
USA
Xilinx also supports HDL initialization of registers in its FPGAs and CPLDs.
I've never needed an asynchronous reset in my Xilinx FPGA projects.
robinh
Member level 1
Signal and port assignment are discarded during the synthesis process. This feature is only destined to simulation and modeling purposes. This is the reason why you get two different results.
The only thing you can give a fixed value during definition is a constant.
FvM
Super Moderator
Staff member
Bochum, Germany
How do you know? From literature? Believe it or not, FPGA registers have a power-up level that can be utilized in designs. This is surely the case with Altera and, as echo47 confirmed, with Xilinx. I love those expert statements in EDAboard, that aren't founded on any real knowledge.
Port assignments to external ports are actually meaningless in synthesis, assignments to internal ports work in the same way as in simulation, they are valid as default for unconnected ports only.
amir81
Member level 2
as a general rule: initialization of signals (also ports because they are signals) are not synthesizable. neither xilinx nor altera, actel,ql,... support that.
however for some fpgas you can use some attributes ( such as init for xilinx fpgas) to initialize ram or lut.
but remember fpga synthesizers ALWAYS ignore initializations of signals ( try with xst, synplify, leonardo and ... you will get same result). however as far as i know if you want to make an asic you can use signal initialization ( i do not work with asics).
vomit
Full Member level 2
amir81 said:
as a general rule: initialization of signals (also ports because they are signals) are not synthesizable. neither xilinx nor @ltera, actel,ql,... support that.
You're right in general. But recently I learned in a Xilinx presentation at our company that their ISE synthesis tool does support initial values. I was rather sceptic, asked it again and got a formal yes.
FvM
Super Moderator
Staff member
Bochum, Germany
See an example from Quartus handbook with VHDL code of a Register with Reset and High Power-Up Level.
SIGNAL q : STD_LOGIC := '1'; -- q has a default value of '1'
PROCESS (clk, reset)
  BEGIN
    IF (reset = '1') THEN
      q <= '0';
    ELSIF (rising_edge(clk)) THEN
      q <= d;
    END IF;
  END PROCESS;
So far regarding "neither Altera supports"...
The mechanism behind this code is also explained in Quartus handbook:
Registers in the device core always power up to a low (0) logic level on all Altera devices. However, there are ways to implement logic such that registers behave as if they were powering up to a high (1) logic level.
So the power-up level is actually an option of the synthesis tool, not a harware feature. But is exists and apart from synthesis attributes and such it can be inferred from HDL initilization statements.
I did not claim, that this option exists with all synthesis tools, cause I simply don't know. I assume, that some others tools also offer the option, but probably not all. I may be more difficult for a vendor independant tool. According to the handbook, e. g. Synopsys doesn't support Verilog initial statement.
echo47
USA
HDL register initialization in Xilinx ISE is described in the XST User Guide chapters "VHDL Language Support" and "Verilog Language Support":
