sgreen
Junior Member level 3
I used ATmega32A to scan a keypad every 30ms. I want to create interrupt in Clear Timer on Compare Match (CTC) Mode. But interrupt is not working. What is the problem in my code? Code is included here.
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 #include <avr/io.h> //#include <util/delay.h> #include <avr/interrupt.h> // Port Mapping #define KEYPAD_UPPER_PORT_DIR DDRA #define KEYPAD_UPPER_PORT_DATA PORTA #define KEYPAD_UPPER_PORT_IN PINA #define KEYPAD_LOWER_PORT_DIR DDRB #define KEYPAD_LOWER_PORT_DATA PORTB #define KEYPAD_LOWER_PORT_IN PINB #define TASK_PERIOD_DEBOUNCE_MS 30 volatile uint32_t task_time_debounce = TASK_PERIOD_DEBOUNCE_MS; unsigned char key; void timer0_init(void); int main(void) { timer0_init(); while(1) { if(task_time_debounce==0) { KEYPAD_UPPER_PORT_DIR &= 0x0f; KEYPAD_UPPER_PORT_DATA |= 0xf0; KEYPAD_LOWER_PORT_DIR |= 0x0f; KEYPAD_LOWER_PORT_DATA &= 0xf0; //_delay_us(5); key = (KEYPAD_UPPER_PORT_IN & 0xf0); // Get lower nibble KEYPAD_LOWER_PORT_DIR &= 0xf0; KEYPAD_LOWER_PORT_DATA |= 0x0f; KEYPAD_UPPER_PORT_DIR |= 0xf0; KEYPAD_UPPER_PORT_DATA &= 0x0f; //_delay_us(5); key = key | (KEYPAD_LOWER_PORT_IN & 0x0f); task_time_debounce=TASK_PERIOD_DEBOUNCE_MS; } } } void timer0_init(void){ TIMSK |= (1<<OCIE0); TCCR0 = (1<<WGM01); //Timer in CTC mode TCCR0 = ((1<<CS01)|(1<<CS00)); //1:64 prescaler OCR0=249; //Value to have an compare at every 1ms //Enable timer interrupts sei(); //Enable global interrupts } ISR (TIMER0_COMP0_Vect) { // update system time //systime++; // decrement debouncing task time if (task_time_debounce > 0) { task_time_debounce--; } }
