hez_91
Newbie level 5
Hi
I am experiencing some difficulties in trying to get the TIMER1 to run in my interrupt routine.
In my interrupt routine, it has a password input module that waits for the input of the password in a for loop. During that time, I am suppose to set a time-limit for the input before sending off an alarm but timer1 interrupts are not active during my external interrupt routine. Is there anyway around this or am i doing anything wrong?
#include <p18f4520.h>
#include <delays.h>
#include <stdio.h>
#include <string.h>
#include <usart.h>
#include <stdlib.h>
void checkInputs(void);
void sendSMS(void);
void passwordPrompt(void);
//void receive_sms(void);
int pb, dip_sw, x, check, count, count2, systemArmed, y;
void high_isr(void); // prototype of function high_isr
#pragma code high_vector = 0x08
void high_vector(void)
_asm goto high_isr _endasm //jump to interrupt routine
#pragma code //return to default code section
#pragma interrupt high_isr
void high_isr(void)
if(INTCONbits.INT0IF) //Arm button
systemArmed = 2;
Delay10KTCYx(200);
if(INTCON3bits.INT2IF){ // Sound detected
if(systemArmed==2)
Delay10KTCYx(200);
if(PORTBbits.RB2 = !PORTBbits.RB2) // Glass break sensor triggered
T0CONbits.TMR0ON = 0;
INTCONbits.TMR0IF = 0;
INTCONbits.TMR0IE = 0;
PORTBbits.RB5 = ~PORTBbits.RB5;
passwordPrompt();
T0CONbits.TMR0ON = 1;
INTCONbits.TMR0IE = 1;
// sendSMS();
INTCON3bits.INT2IF = 0;
if (INTCONbits.TMR0IF) { // Check for Timer0 overflow
TMR0H = 0x0B; // Clear Timer0 high byte register
TMR0L = 0xDC; // Clear Timer0 low byte register
if(systemArmed==2)
count++;
if(count==10) //After 10 seconds, read as idle and go into sleep mode
PORTBbits.RB3 = ~PORTBbits.RB3;
count = 0;
// Sleep();
INTCONbits.TMR0IF = 0; // Clear Timer0 interrupt flag
if (PIR1bits.TMR1IF)
TMR1H = 0x0B; // Clear Timer0 high byte register
TMR1L = 0xDC; // Clear Timer0 low byte register
count2++;
if(y==1)
if(count2==10)
count2=0;
sendSMS();
// T1CONbits.TMR1ON = 0;
PIR1bits.TMR1IF = 0;
void main()
count = 0;
count2 = 0;
systemArmed = 0;
TRISA = 0b11111111;
TRISB = 0b11010111;
TRISC = 0b10111111;
TRISD = 0xff;
PORTA = 0x00;
PORTB = 0x00;
PORTD = 0;
SPBRG = 25;
TXSTA = 0b00100100;
RCSTA = 0b10010000;
RCONbits.IPEN = 0;
//INTCON2bits.INT2IP = 1; // IP2 high priority
INTCONbits.INT0IF = 0; // clear IF first
INTCONbits.INT0IE = 1; // Enable INT2
INTCON3bits.INT2IP = 0; // IP2 high priority
INTCON3bits.INT2IF = 0; // clear IF first
INTCON3bits.INT2IE = 1; // Enable INT2
INTCON2bits.INTEDG2 = 0;
INTCON2bits.TMR0IP = 1; // Set Timer0 interrupt to low priority
INTCONbits.TMR0IF = 0; // clear IF first
INTCONbits.TMR0IE = 1; // Enable Timer0 overflow interrupt
T0CON = 0b10000011; // On Timer0, set to 16-bit mode,
// Use internal instruction clock,
// Rising-edge trigger, set prescaler to 1:8
IPR1bits.TMR1IP = 1;
PIE1bits.TMR1IE = 1;
TMR1H = 0x0B;
TMR1L = 0xDC;
T1CON = 0b00110001;
INTCONbits.GIEL =1;
INTCONbits.GIE = 1;
Sleep();
PORTBbits.RB3 = 1;
void passwordPrompt()
count = 0; // reset time into idle status
count2 = 0;
y = 1;
for(x=0;x<10;x++) // loop
dip_sw = PORTD & 0x0f; // read dip switches
Delay10KTCYx(150);
pb = PORTD & 0xf0; // read push buttons
pb >>=4; // shift the upper nibble to the lower nibble
if(pb == dip_sw) //compare dip with push buttons
x = 0; // reset number of tries
PORTBbits.RB5 = 1; // Light up RED LED
Delay10KTCYx(100);
PORTBbits.RB5 = 0; // Off RED LED
systemArmed = 0;
break;
else if (pb != 0x0f)
PORTBbits.RB3 = 1; // Light up GREEN LED
Delay10KTCYx(100);
PORTBbits.RB3 = 0; // Off GREEN LED
x++;
if(x==3) // number of tries allowed
// alarm(); //sound alarm
PORTBbits.RB5 = 1; // Light up red LED
sendSMS();
break;
// PORTBbits.RB4 = 1; // Start recording
x--;
