bizoo
Member level 5
Feeding the Interrupt line of the PCI bus from the motherboard to another device
HI all,
I am basically a software engineer who had a small circuit design issue and need some guidance.
I need to take the interrupt line of the PCI card from my motherboard and feed into a small FPGA which has a dedicated input connector.
I have measured the signal on the PCI interrupt and its active low and pulled up to 5V with pull up registers when no activity is on the line . The FPGA input signal requirement is 3.3 Volts.
Now from my limited knowledge of electronics, i can remember that for dividing the voltage i need a couple of resistors with the right ratio.
But the FPGA is an expensive one and i do not want to blow anything up. I am not sure about the role of pull up resistors and how the active low logic will affect my input to the FPGA.
Pretty trivial question for some but as i said, i am a software enginner and had my last interaction with hardware design some 6 years ago in University.
Any help will be appreciated!
cheers!
HI all,
cheers!
