interrupt doesn't work help plz
giacciu
Newbie level 1
this is a simple code that turn on the led on rb4 when ccp1 feel the first rising edge maded by another pic
void interrupt()
if(PIR1.CCP1IF==1)
PORTB=0b00010000;
PIR1.CCP1IF =0;
void main()
TRISC=1;
TRISB=0;
T1CON=0b00110001;
CCP1CON=0b00000101;
T1CON.TMR1ON=1;
INTCON.PEIE = 1;
PIE1.CCP1IE = 1;
PIR1.CCP1IF=0;
INTCON.GIE = 1;
while(1) //endless loop
delay_ms(500);
PORTB=0b00100000;
delay_ms(500);
PORTB=0;
the led on rb5 blink forever , so it don't feel the interrupt
help me please
does it blink forever? stays ON forever? or off forever?
Where is the function interrupt() being called in the main?
just check the void intrupt() function is correct because in some controllers the intrupt subroutine function might be different form just check the application.
did u wrote the routine in the same vector address?
