Note: This feature currently requires accessing the site using the built-in Safari browser.
this is a preprocessor #define directive - when it finds the identifier device in your code replaces it with *(( volatile unsigned long *) (0x1000000))Hi how do I interpret "*" in the following C syntax, is it a form of type casting?
#define device *(( volatile unsigned long *) (0x1000000))
Thanks
Does this make sense:
device is a pointer to a unsigned long which holds the address 0x10000000
#define device *(( volatile unsigned long [COLOR="#FF0000"]*[/COLOR]) ([COLOR="#FF0000"]0x1000000[/COLOR]))
#define device *(( volatile [COLOR="#FF0000"]unsigned long[/COLOR] *) (0x1000000))
#define device *(( [COLOR="#FF0000"]volatile[/COLOR] unsigned long *) (0x1000000))
#define device *[COLOR="#FF0000"](( volatile unsigned long *) (0x1000000))[/COLOR]
#define device [COLOR="#FF0000"]*[/COLOR](( volatile unsigned long *) (0x1000000))
unsigned long tmp;
tmp = *(( volatile unsigned long *) (0x1000000));
unsigned long tmp = 0xFFFFFFFF;
*(( volatile unsigned long *) (0x1000000)) = tmp;
unsigned long tmp;
tmp = device;
device = tmp;
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 //******************************************************* ********************** // // tm4c123gh6pm.h - TM4C123GH6PM Register Definitions // // Copyright (c) 2013 Texas Instruments Incorporated. All rights reserved. // Software License Agreement // // Redistribution and use in source and binary forms, with or without // modification, are permitted provided that the following conditions // are met: // // Redistributions of source code must retain the above copyright // notice, this list of conditions and the following disclaimer. // // Redistributions in binary form must reproduce the above copyright // notice, this list of conditions and the following disclaimer in the // documentation and/or other materials provided with the // distribution. // // Neither the name of Texas Instruments Incorporated nor the names of // its contributors may be used to endorse or promote products derived // from this software without specific prior written permission. // // THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS // "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT // LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR // A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT // OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, // SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT // LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, // DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY // THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT // (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE // OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. // // This is part of revision 1.0 of the Tiva Firmware Development Package. // //***************************************************************************** #ifndef __TM4C123GH6PM_H__ #define __TM4C123GH6PM_H__ //***************************************************************************** // // Watchdog Timer registers (WATCHDOG0) // //***************************************************************************** #define WATCHDOG0_LOAD_R (*((volatile unsigned long *)0x40000000)) #define WATCHDOG0_VALUE_R (*((volatile unsigned long *)0x40000004)) #define WATCHDOG0_CTL_R (*((volatile unsigned long *)0x40000008)) #define WATCHDOG0_ICR_R (*((volatile unsigned long *)0x4000000C)) #define WATCHDOG0_RIS_R (*((volatile unsigned long *)0x40000010)) #define WATCHDOG0_MIS_R (*((volatile unsigned long *)0x40000014)) #define WATCHDOG0_TEST_R (*((volatile unsigned long *)0x40000418)) #define WATCHDOG0_LOCK_R (*((volatile unsigned long *)0x40000C00)) //***************************************************************************** // // Watchdog Timer registers (WATCHDOG1) // //***************************************************************************** #define WATCHDOG1_LOAD_R (*((volatile unsigned long *)0x40001000)) #define WATCHDOG1_VALUE_R (*((volatile unsigned long *)0x40001004)) #define WATCHDOG1_CTL_R (*((volatile unsigned long *)0x40001008)) #define WATCHDOG1_ICR_R (*((volatile unsigned long *)0x4000100C)) #define WATCHDOG1_RIS_R (*((volatile unsigned long *)0x40001010)) #define WATCHDOG1_MIS_R (*((volatile unsigned long *)0x40001014)) #define WATCHDOG1_TEST_R (*((volatile unsigned long *)0x40001418)) #define WATCHDOG1_LOCK_R (*((volatile unsigned long *)0x40001C00)) //***************************************************************************** // // GPIO registers (PORTA) // //***************************************************************************** #define GPIO_PORTA_DATA_BITS_R ((volatile unsigned long *)0x40004000) #define GPIO_PORTA_DATA_R (*((volatile unsigned long *)0x400043FC)) #define GPIO_PORTA_DIR_R (*((volatile unsigned long *)0x40004400)) #define GPIO_PORTA_IS_R (*((volatile unsigned long *)0x40004404)) #define GPIO_PORTA_IBE_R (*((volatile unsigned long *)0x40004408)) #define GPIO_PORTA_IEV_R (*((volatile unsigned long *)0x4000440C)) #define GPIO_PORTA_IM_R (*((volatile unsigned long *)0x40004410)) #define GPIO_PORTA_RIS_R (*((volatile unsigned long *)0x40004414)) #define GPIO_PORTA_MIS_R (*((volatile unsigned long *)0x40004418)) #define GPIO_PORTA_ICR_R (*((volatile unsigned long *)0x4000441C)) #define GPIO_PORTA_AFSEL_R (*((volatile unsigned long *)0x40004420)) #define GPIO_PORTA_DR2R_R (*((volatile unsigned long *)0x40004500)) #define GPIO_PORTA_DR4R_R (*((volatile unsigned long *)0x40004504)) #define GPIO_PORTA_DR8R_R (*((volatile unsigned long *)0x40004508)) #define GPIO_PORTA_ODR_R (*((volatile unsigned long *)0x4000450C)) #define GPIO_PORTA_PUR_R (*((volatile unsigned long *)0x40004510)) #define GPIO_PORTA_PDR_R (*((volatile unsigned long *)0x40004514)) #define GPIO_PORTA_SLR_R (*((volatile unsigned long *)0x40004518)) #define GPIO_PORTA_DEN_R (*((volatile unsigned long *)0x4000451C)) #define GPIO_PORTA_LOCK_R (*((volatile unsigned long *)0x40004520)) #define GPIO_PORTA_CR_R (*((volatile unsigned long *)0x40004524)) #define GPIO_PORTA_AMSEL_R (*((volatile unsigned long *)0x40004528)) #define GPIO_PORTA_PCTL_R (*((volatile unsigned long *)0x4000452C)) #define GPIO_PORTA_ADCCTL_R (*((volatile unsigned long *)0x40004530)) #define GPIO_PORTA_DMACTL_R (*((volatile unsigned long *)0x40004534)) //***************************************************************************** // // GPIO registers (PORTB) // //***************************************************************************** #define GPIO_PORTB_DATA_BITS_R ((volatile unsigned long *)0x40005000) #define GPIO_PORTB_DATA_R (*((volatile unsigned long *)0x400053FC)) #define GPIO_PORTB_DIR_R (*((volatile unsigned long *)0x40005400)) #define GPIO_PORTB_IS_R (*((volatile unsigned long *)0x40005404)) #define GPIO_PORTB_IBE_R (*((volatile unsigned long *)0x40005408)) #define GPIO_PORTB_IEV_R (*((volatile unsigned long *)0x4000540C)) #define GPIO_PORTB_IM_R (*((volatile unsigned long *)0x40005410)) #define GPIO_PORTB_RIS_R (*((volatile unsigned long *)0x40005414)) #define GPIO_PORTB_MIS_R (*((volatile unsigned long *)0x40005418)) #define GPIO_PORTB_ICR_R (*((volatile unsigned long *)0x4000541C)) #define GPIO_PORTB_AFSEL_R (*((volatile unsigned long *)0x40005420)) #define GPIO_PORTB_DR2R_R (*((volatile unsigned long *)0x40005500)) #define GPIO_PORTB_DR4R_R (*((volatile unsigned long *)0x40005504)) #define GPIO_PORTB_DR8R_R (*((volatile unsigned long *)0x40005508)) #define GPIO_PORTB_ODR_R (*((volatile unsigned long *)0x4000550C)) #define GPIO_PORTB_PUR_R (*((volatile unsigned long *)0x40005510)) #define GPIO_PORTB_PDR_R (*((volatile unsigned long *)0x40005514)) #define GPIO_PORTB_SLR_R (*((volatile unsigned long *)0x40005518)) #define GPIO_PORTB_DEN_R (*((volatile unsigned long *)0x4000551C)) #define GPIO_PORTB_LOCK_R (*((volatile unsigned long *)0x40005520)) #define GPIO_PORTB_CR_R (*((volatile unsigned long *)0x40005524)) #define GPIO_PORTB_AMSEL_R (*((volatile unsigned long *)0x40005528)) #define GPIO_PORTB_PCTL_R (*((volatile unsigned long *)0x4000552C)) #define GPIO_PORTB_ADCCTL_R (*((volatile unsigned long *)0x40005530)) #define GPIO_PORTB_DMACTL_R (*((volatile unsigned long *)0x40005534))
#define GPIO_PORTA_DATA_R [COLOR="#FF0000"]([/COLOR]*((volatile unsigned long *)0x400043FC)[COLOR="#FF0000"])[/COLOR]
