s_cihan_tek
Full Member level 2
as-i parameter
Hi all,
I'm trying to use a 74lvc4245 level shifter to shift the voltage levels of the 8bit data lines between a 3.3V FPGA (max ii) and a 5V LCD. I wasn't able to decide if current limiting resistors or something else is needed in these connections below:
1- Connection btw. the FPGA and the level shifter
2- Connection btw. the level shifter and the LCD
And here are the related datasheets and page numbers of the related specs.
FPGA at pages ..74..
74lvc4245
There isn't any info about i/o currents in the LCD datasheet so i'm not giving its url here.
I would really appretiate if someone could show me how to interprete these I/O parameters when connecting the i/o pins of these IC's together.
Regards...
Hi all,
74lvc4245
Regards...
