INTERNAL_ERROR:Xst:cmain.c:3464:1.56 - Process will terminate.
isamel85
Newbie level 6
Newbie level 6
Who has the same problem can give me a hand? thanks so much! the problem is: INTERNAL_ERROR:Xst:cmain.c:3464:1.56 - Process will terminate. For technical support on this issue, please open a WebCase with this project attached at https://www.xilinx.com/support.
knowing that the Release version for the ISE Project Navigator is 14.6.
Plz help me.
There are so many possible internal errors and they are usually caused by memory problems with the computer or some poorly written code that causes XST to "blow up". I've only run across a few times where XST did this and it was actually a documented bug. If you want help you won't find it here for something Xilinx says to attach to a WebCase.
About the best you can hope for is posting your project here and see if anyone else can duplicate your issue. Or see if the issues doesn't occur on another version of the tools.
