[SOLVED] Internal clock problem?
hemnath
Advanced Member level 3
Chennai
I'm using internal clock in PIC18F2520 using CCS c compiler. I'm displaying a string "SECONDS" and displays counting numbers from 0,1,2,3...
When i power, it shows "SECONDS 0" in the display and after 18 seconds only, it starts incrementing its value. Why is it so? Please help.. Once it's starts incrementing, it counts for every second,thats normal.
HTML:
#include <18F2520.h>
#include <string.h>
#fuses INTRC_IO,NOWDT,NOLVP,PUT
#use delay(clock=31000)
#define EN     PIN_A1
#define RS     PIN_A2
#define INTS_PER_SECOND  15                   //15.1371 // (31000/(4*2*256))
INT16 seconds;
BYTE INT_count;
#INT_rtcc
void clock_isr()
   if (--INT_count == 0)
      ++seconds;
      INT_count = INTS_PER_SECOND;
void lcd_cmd(CHAR a);  // function declaration
void lcd_print(CHAR rstr[]);
CHAR msg[16];
void main ()
   set_timer0 (0) ;
   setup_counters (RTCC_INTERNAL, RTCC_DIV_2|RTCC_8_BIT);
   enable_interrupts (INT_RTCC) ;
   enable_interrupts (GLOBAL) ;
   output_low (RS);//set LCD to command mode
   lcd_cmd (0x30);
   lcd_cmd (0x01);
   lcd_cmd (0x02);
   lcd_cmd (0x0c);
   lcd_cmd (0x06);
   seconds =0;
   WHILE (1)
       lcd_cmd (0x02);//move cursor to home position
       sprintf (msg, "SECONDS %LU  ",  seconds ) ;
       if (seconds==1)
            output_high(pin_a3);
       lcd_print (msg);
   output_b (a);
   delay_ms (10);
   output_high (EN);
   delay_ms (10);
   output_low (EN);
   INT i;
   FOR (i=0; rstr[i]!='\0';  i++)
      output_high (rs);
      lcd_cmd (rstr[i]);
As a guess, I would think the problem is that you don't initialize the "seconds" variable or timer ready for it's first count. The interrupt occurs when the timer has reached terminal value and rolled over to zero so if it starts frm zero it has to count it's full range of values before the first interrupt occurs.
Warning - it looks like you are using the internal 31KHz clock - bear in mind it isn't very accurate or stable if you are using it for critical timing applications.
Brian.
Thanks for your replay. But i had already solved the problem and forgot to mark it as solved.
Thanks...
Error in code:
In your application,
1 second is on INT_count value upto 15.
as INT_count has initially zero value it will first decrease by 1 and its value become 255.
initial time taken will be 256/15=17.06S.
Solution:
initialize the global variable.
BYTE INT_count = INTS_PER_SECOND;
