Intermittent problem - help needed
brunofunchas
Full Member level 3
Portugal
This components can cause an intermittent problem?
- Transistor. Even if it checks ok with analog multimeter?
- Resistor. If it goes up in its value?
- Integrated circuits
- GND track with noise. How can we solve this problem? Soldering a wire between ground points?
Or "only" cold joints, capacitors, etc can cause this type of problem?
Thanks,
Bruno
Re: Intermittent problem
I have a DC drive that changes the velocity of the motor intermittent.
I have checked the power supply and it is ok. It is an old board that has a lot of analog in it. It has a lot of transistors and resitors.
Best regards,
Bruno
Is it a double or single sided pcb? How much time does it stay malfunctioning? Try to freeze some portions of the circuit using a spray.
Some hints:
1- Resolder all components. Soldering points tend to degrade with age, even if you can´t see this (always happens in single sided boards, depending on age).
2- Older ceramic capacitors show intermittent shorts. Sometimes they work well when heated or resoldered but fail again after some time.
3- Resistors (mainly 1W or more) show intermittent failures.
4- In rare ocasions a bjt also fails intermittently.
5- xtal oscillators, diodes, zenners, etc also ....
It is a single sided PCB.
Thanks for the tips / Obrigado pela ajuda,
Bruno
Single sided boards ALWAYS have problems with soldering after some years. I strongly suggest your resoldering all components.
Added after 6 minutes:
Search for solder joints like the one in the attached image.
It was a transistor with an intermittent problem.
Thanks for the tips.
Best regards,
Bruno
