Dec 28, 2009 #1 J jankrish Newbie level 5 Joined Feb 19, 2009 Messages 8 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,340 How to implement interleaver for qpsk/bpsk modulated signal in MATLAB.please attach any code related to interlever in case you have. Its quite urgent please. Thank you.
Dec 28, 2009 #2 RBB Full Member level 5 Joined Jul 2, 2007 Messages 303 Helped 71 Reputation 142 Reaction score 36 Trophy points 1,308 Location USA Activity points 2,560 What type of interleaver?
Oct 24, 2010 #3 S sajjadhyd Junior Member level 1 Joined Sep 23, 2010 Messages 18 Helped 1 Reputation 2 Reaction score 1 Trophy points 1,283 Location pakistan Activity points 1,370 i need a matlab code for bit interleaving and byte interleaving
Oct 25, 2010 #4 C Communications_Engineer Advanced Member level 3 Joined Oct 10, 2008 Messages 894 Helped 179 Reputation 358 Reaction score 105 Trophy points 1,323 Location Sindh, Pakistan Activity points 5,542 type doc interleaver in the command window typically, there is a bit interleaver, but you can always convert bits into bytes (or from boolean to decimal for your case :wink)
Oct 26, 2010 #5 S sajjadhyd Junior Member level 1 Joined Sep 23, 2010 Messages 18 Helped 1 Reputation 2 Reaction score 1 Trophy points 1,283 Location pakistan Activity points 1,370 i had not found there if u have please give to me... i need a matlab code of interleaving for wireless applications....or wimax
Oct 26, 2010 #6 C Communications_Engineer Advanced Member level 3 Joined Oct 10, 2008 Messages 894 Helped 179 Reputation 358 Reaction score 105 Trophy points 1,323 Location Sindh, Pakistan Activity points 5,542 nope. I won't just give you unless you are actually willing to work. type doc intrlv and you will find it in matlab
Oct 30, 2010 #7 R realbaltalyus Junior Member level 1 Joined Nov 30, 2009 Messages 19 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,281 Location Turkey Activity points 1,389 both type doc intrlv and deintrlv, These docs help you
