Interleaved sync buck converter (8 bucks into one output)
T
treez
Hello,
Just wondered if anyone knows of a sync Buck converter (preferably from linear.com) which has facility to interleave with 8 other same controllers?
(ie, each one switching 360/8 degrees apart.)
Spec for each buck is:-
Vin=24v, vout=1.5v, iout=12A (each), ton(minimum)<200ns,
(so the entire, collective output is 1.5V & 8*12A)
The most common six-phase converters are from Intersil. At least the circuits I've seen up close.
The ISL6398 can be cascaded for up-to 24 phases.
Reactions: treez
    T
I adapted one of my simulations to your specs. It just so happens that the duty cycle is short enough so it can be rotated through the 8 converters, one after the other.
A 4017 IC (1-of-10 counter) is all it takes to rotate pulses to 8 buck converters. Each turns on for 12.5 percent duty cycle. Total output is 1.5V, 100A.
The switching frequency does not need to be as slow as I have it, of course.
This is vastly simplified from your specs. Nevertheless it is interesting as an experiment, to observe the waveforms, and current levels, that might be expected.
Reactions: treez
    T
With Brad's solution to generate 8 pulses...you could add 8 synchronizeable buck converters.
Klaus
Reactions: treez
    T
