Interfacing Xilinx Coregen generated RAM with AHB interface
urakiki
Junior Member level 1
I use xilinx coregen to generate ram. Can I interface this ram with AHB interface. If no what modification should i do? Thanks
KIKI
AMBA AHB ram
u need to write a wrapper for ur ram to make ur module compatible with the ahb signals.
it may be a master or slave port depending on ur application.
if ur ram has to write out data to any peripheral then u have to write a master interface. if ur ram doesn't have to write out any data and only accepts data that is some peripheral writes to your module a slave port is sufficient.
refer the amba ahb manual for implementation.
page no 79 and 83.
regards
srinivas
