interfacing xbee and 8051 microcontroller
zahoor1701
Newbie level 1
can rx and tx pins of xbee module can be directly connected to txd and rxd pins of microcontroller.i am using xbee s2c module and at89s52.
andre_luis
Super Moderator
Staff member
Brazil
The Xbee module is supplied with 3.3v, so at first sight you should add a level converter to interface the at89s52, which is supplies with 5v. However, for most cases a simple resistos divisor arrangement pretty suffice.
KlausST
Super Moderator
Staff member
As a general rule:
All information is given in the datasheets.
For IOs:
* absolute maximum ratings of IO.
* VIL,
* VIH,
* VOL
* VOH
I think no person can have all those values for all devices in mind, therefore it is necessary to read the datasheets.
Klaus
