[PIC] Interfacing USB to PIC24
Raady Here
Full Member level 5
Full Member level 5
India
PIC24FJ128GC006
MPLab8.8V,
I am trying to interface a USB to my PIC, can any body provide the interface connections.
In my project I am monitoring adc channel and do the required calculation on it and can see those working fine by printing on Hyeprterminal. Now need to save those values by adding a USB and switch button , so that if I press the switch button it will save that variables in the USB as a file. As a part of it I am trying to interface USB to my PIC, unfortunately I didn't any relevant documents. how I can proceed further ?
Pins that I have for USB are Vcc,D+,D-,Gnd.
I have gone through it, but its about connections with Micro/mini USB devices, I need connections for a standard USB flash device, thats why I mentioned I have only 4 pins on my USB - D+,D-,Vcc,Gnd. I got confused where to connect Vbus in this case and how do I get device address when no connections could be made to USBID.
IN that case you are using the USB on the PIC in host mode and so Figure 27-7 in the FRM document mentioned by Ravindragudi and in particular look at Note 1. You might not want the circuit connected tothe "A/D pin" but you WILL want the 5V to the Vcc pin of the USB connector.
Also look in the Microchip Application Library for the USB host MSD demo code.
Susan
