Interfacing to a small screen
q-bertsuit
Junior Member level 3
I bought this TFT screen that id like to use in a project. When I bought it I was under the impression that it would be easy to interface it to a standard VGA source, but this seems not to be the case. The controller for the screen takes an 8 bit parallel input.
Is it possible to interface this type of screen with say, a Raspberry Pi or even my computer, to act as a monitor? Are there any chips you know of that takes HDMI/DVI/VGA and converts it to the parallel RGB type the controller takes? I found a dev board from the same company that can display composite video, but I haven't found anything for VGA.
Thank you
Are you looking for this type of chip... Like AD9882 which will give VGA output means RGB data out with Hsyc, Vsync and Blank_EN etc...
http://www.datasheetcatalog.org/datasheet/analogdevices/AD9882_PCB.pdf
If you cant find the solution, can you please describe more about your need... ?
means what is the scenario that you are facing...?
Because the display pannel should need the HSYNC, VSYNC, BLANK_EN pulses with the RGB data (8 bit, 16 bit, 24 bit format....)
I think you need a CPLD and DVI receiver to covert HDMI/DVI to the 8-bit parallel video data. For low resolution DVI/HDMI interface, spartan6 FPGA could be a single chip solution.:cool:
