interfacing rtc with pic18
adm1
Junior Member level 1
I am doing this for the first time and getting stuck. cAN anyone please help me out in this -
I need to interface a pic microcontroller (preferably pic18) with a real time clock- either using ds1307 or any other RTC chip.
My e-mail id is adi265ster@gmail.com
You need to first read datasheet of ds 1307. How it gives date and time. Make hardware, connect two wire interface to ds 1307. Write code to read the addresses of ds 1307. Code is attached.
NIKS
Thank you, I shall try it.
But only the header files are there in the attachment, how do i use it ?
do i use a software like mikroc or sumthing?
Anyways thank you.
thank you so much to all...
after two months of struggle, i managed to write data into rtc and read data from it. it usually takes much lesser time for experts...but i am still a beginner, and doing a project for the first time.
my next challenge is to store the date and time into a memory card... i really need some help on this --
thank you nikunj and tahmid...
The DS3232 is also a good IC if you want to try :D
