interfacing PIC16F84 to PC's Serial Port
buffster88
serial communication
hi!
can someone tell me how i could store a value in a pic 16f84 and later send it to pc with serial port in vb6. also would i have to use a max232.
thanks!
ya you have to use level converter MAXIM IC and what data you are sending?
Re: serial communication
Thanks for replying. Im getting an analog voltage in and converting it to digital. I want to store the digital number and send it at a later stage.
You can store your digital data in the PIC's EEPROM then, send it to the PC whenever you want.
Yes, you will have to use a MAX232 to convert the TTL level of the PIC to +-10 of the Serial port.
This is the connection between the MAX232, the PC and, the PIC
https://www.coolcircuit.com/circuit/rs232_driver/max232.gif
