Interfacing pic 16f688 with TELIT gprs modem
khamar_98495
Newbie level 3
I am interfacing pic 16f688 with TELIT gprs modem.
When i send AT command to GPRS modem, i was able to receive "OK" in hyper terminal.
similarly if i send AT command to GPRS modem from pic, it is responding with "OK". I was not able to store this OK in micro controller.
This OK is coming till receiver pin of micro controller but not able to store in a buffer.
Please help me.
Thanks in advance
Why cannot you store the data 'OK' ??
Post your program source code so we can see what you are trying to do.
Hi wp100,
Here i am attaching the code, Please do the needfull.
#include "htc.h"
#include "Pic.h"
#include "pic16f688.h"
__CONFIG(FCMDIS & IESODIS & CPD & MCLREN & WDTDIS & INTIO & PWRTEN & INTCLK & BOREN);
unsigned char receive_byte; //variable to store byte from RCREG
unsigned char receive_array[10]; //Array to store the response
unsigned int long d;
void OscillatorConfiguration(void) //Oscillator initialise
OSCCON = 0x71;
void UartInit(void) //uart initialise
//BRG16 = 0; // tO DO
SPBRG = 12;
BRGH = 0; //data rate for sending
SYNC = 0; //asynchronous
SPEN = 1; //enable serial port pins
CREN = 1; //enable reception
SREN = 0; //no effect
TXIE = 0; //disable tx interrupts
RCIE = 0; //disable rx interrupts
TX9 = 0; //8-bit transmission
RX9 = 0; //8-bit reception
TXEN = 0; //reset transmitter
TXEN = 1; //enable the transmitter
void UartTxChar(unsigned char ch) //function to transmit character
//CLRWDT();
while(!TXIF);
TXREG = ch;
void UartTxString(unsigned char *str) //function to transmit string
while(*str != '\0')
UartTxChar(*str++);
UartTxChar(13);
void serial_receive() //function to take the value from RCREG
while((RCIF == 0) && (d != 50000))
d++;
if(RCIF)
receive_byte = RCREG;
RCIF = 0;
else
receive_byte = 'A';
void receive() //function to store the received vale in array
unsigned char i;
d = 0;
for( i = 0; i < 9; i++)
serial_receive();
receive_array = receive_byte;
void main(void)
OscillatorConfiguration();
UartInit();
UartTxString((unsigned char*)"AT");
receive();
UartTxString(receive_array);
while(1);
Thank you in advance
