Interfacing PC to DAC through SPI
h.a.o
Newbie level 3
My DAC contains an SPI interface
How can I connect it to my PC?
Then can I use MATLAB to send data to the DAC?
Use a dll like io.dll to gain access to the parallel port in VB6 or a .NET compiler or any other program that can access dlls. Then use one pin as clock, one as data and one as chip select if you wish to access more than one chip, otherwise just tie the devices CS pin to the appropriate logic level.
