interfacing pc to a 8051 micro controller
dawuzi
Newbie level 6
hi everyone. i have not interface a micro controller to a pc before. i would like to send three set of data from some the micro controller to a computer so that it can be displayed on the screen of a pc. I have heard of parallel and serial communication but i dont know where to start from. A sort beginner tutorial will be helpful
ckshivaram
Advanced Member level 5
villingen (Germany) / Bangalore
you can do serial communication with the microcontroller...
visit 8052.com - The Online 8051/8052 Microcontroller Resource - 8052.com and read the tutorials and sample program... you will get idea.
---------- Post added at 20:11 ---------- Previous post was at 20:08 ----------
check this
Serial Communication programming using Microcontroller : 8051 Microcontroller Projects AVR PIC Projects Tutorials Ebooks Libraries codes see for 8051 Programming for UART
8051 Tutorial: Serial Communication - 8052.com
Reactions: dawuzi
    dawuzi
dawuzi
Newbie level 6
Thanks so much. The tutorial explained sending ascii. Another problem is that the serial communication uses the timer register. I also intend using that register for my application. Let me explain what i want to do exactly. The micro controller timers are configured as event counters. This shows the number of people that entered and left a place respectively. Micro controller also has an 8 bit input data at one of the ports. I would like all these data to be sent to a c# application running on a pc using control signals to identify each particular data. The application will also be a signal to the micro controller for it to execute an interrupt. I would also appreciate circuit diagrams
dawuzi
Newbie level 6
Can i use any 8051 micro controller for the interfacing(ie C or S series) or is any one prefferable. I also heard about a program hyperterminal. I would like if am given tips to carry this out. I also dont know if it is possible using a USB to serial converter.
ckshivaram
yes you can do it with the mentioned series.. hyperterminal is a windows package from where you can communicate with external devices through serial communication...
you could use a serial to USB cable also , but serial to serial cable is better preferred....
