dany24
Newbie level 1
Hi friends,
Am posting the code here...in this code am getting a problem that clock runs quickly without going accordingly with our real time clock please help me out please.....
Thanks in advance
#include<reg51.h>
sbit set=P1^2;
sbit mov=P1^3;
sbit inc=P1^4;
sbit dec=P3^7;
sbit ent=P3^6;
void all_disp();
void time_set();
#define First_Line 0x80
#define Second_Line 0xc0
#define Curser_On 0x0f
#define Curser_Off 0x0c
#define Clear_Display 0x01
#define Data_Port P0
sbit Lcd_rs = P2^0;
sbit Lcd_rw = P2^1;
sbit Lcd_en = P2^2;
sbit sda_rtc =P2^5;
sbit scl_rtc =P2^4;
/*sbit Lcd_rs = P3^5;
sbit Lcd_rw = P3^6;
sbit Lcd_en = P3^7; */
void Lcd8_Init();
void Lcd8_Command(unsigned char);
void Lcd8_Write(unsigned char,unsigned char);
void Lcd8_Display(unsigned char,const unsigned char*,unsigned int);
void Lcd8_Decimal2(unsigned char,unsigned char);
void Lcd8_Decimal3(unsigned char,unsigned char);
void Lcd8_Decimal4(unsigned char,unsigned int);
void Delay(unsigned int);
void del();
#define DS1307_ID 0xD0
#define SEC 0x00
#define MIN 0x01
#define HOUR 0x02
#define DATE 0x04
#define MONTH 0x05
#define YEAR 0x06
DS1307_get(unsigned char);
void DS1307_settime(unsigned char, unsigned char, unsigned char);
void DS1307_setdate(unsigned char, unsigned char, unsigned char);
Send2lcd(unsigned char);
void Rtc_Write(unsigned char,unsigned char);
Rtc_Read(unsigned char);
void Rtc_rd_wr_sub();
void Rtc_Init();
void Rtc_Start();
void Rtc_Tx();
void Rtc_Rx();
void Rtc_Stop();
void Rtc_Ack();
unsigned int Rtc_add_wr,Rtc_add_rd;
unsigned char d_rtc,datain_rtc,in_rtc,temp_rtc,dat_rtc,flag_rtc;
unsigned char i,j,a[10],cur=0;
unsigned char sec,hour,min,date,month,year,sec1,hour1,min1,sec2,hour2,min2,hh,mm,ss,dd,mn,yy;
unsigned char count[6]={0x86,0x89,0x8c,0xc6,0xc9,0xcc};
unsigned char dec_hex(unsigned char tt)
if(tt>59)
tt+=36;
else if(tt>49)
tt+=30;
else if(tt>39)
tt+=24;
else if(tt>29)
tt+=18;
else if(tt>19)
tt+=12;
else if(tt>9)
tt+=6;
return(tt);
void all_disp()
sec = DS1307_get(SEC);
min = DS1307_get(MIN);
hour = DS1307_get(HOUR);
date = DS1307_get(DATE);
month = DS1307_get(MONTH);
year = DS1307_get(YEAR);
sec=Send2lcd(sec);
min=Send2lcd(min);
hour=Send2lcd(hour);
date=Send2lcd(date);
month=Send2lcd(month);
year=Send2lcd(year);
Lcd8_Decimal2(0x86,date);
Lcd8_Write(0x88,'-');
Lcd8_Decimal2(0x89,month);
Lcd8_Write(0x8b,'-');
Lcd8_Decimal2(0x8c,year);
Lcd8_Decimal2(0xc6,hour);
Lcd8_Write(0xc8,'.');
Lcd8_Decimal2(0xc9,min);
Lcd8_Write(0xcb,'.');
Lcd8_Decimal2(0xcc,sec);
void main()
Lcd8_Init();
Lcd8_Display(0x80,"RTC TESTING: ",16);
Delay(65000);
Delay(65000);
Lcd8_Command(0x01);
Lcd8_Display(First_Line,"Date:",5);
Lcd8_Display(Second_Line,"Time:",5);
Rtc_Init();
//DS1307_setdate(0x04,0x11,0x11);
//DS1307_settime(0x16,0x00,0x00);
while(1)
all_disp();
if(!set)
time_set();
void time_set()
Lcd8_Display(0x80," TIME SET ",16);
Lcd8_Display(0xc0," MODE ",16);
Delay(65000);
Lcd8_Command(0x01);
all_disp();
cur=0;
while(ent)
Lcd8_Command(0x0f);
Lcd8_Command(count[cur]);
if(mov==0)
while(!mov);
cur++;
if(cur==6)
cur=0;
else if(count[cur]==0x86)
if(inc==0)
while(!inc);
date++;
if(date>=32)
date=1;
Lcd8_Decimal2(count[cur],date);
else if(dec==0)
while(!dec);
date--;
if(date==0xff)
date=31;
else if(count[cur]==0x89)
if(inc==0)
while(!inc);
month++;
if(month>=13)
month=1;
Lcd8_Decimal2(count[cur],month);
else if(dec==0)
while(!dec);
month--;
if(month==0xff)
month=12;
else if(count[cur]==0x8c)
if(inc==0)
while(!inc);
year++;
if(year>99)
year=0;
Lcd8_Decimal2(count[cur],year);
else if(dec==0)
while(!dec);
year--;
if(year==0xff)
year=99;
else if(count[cur]==0xc6)
if(inc==0)
while(inc==0);
hour++;
if(hour>=24)
hour=0;
Lcd8_Decimal2(count[cur],hour);
else if(dec==0)
while(dec==0);
hour--;
if(hour==0)
hour=23;
else if(count[cur]==0xc9)
if(inc==0)
while(inc==0);
min++;
if(min>=60)
min=0;
Lcd8_Decimal2(count[cur],min);
else if(dec==0)
while(dec==0);
min--;
if(min==0)
min=59;
else if(count[cur]==0xcc)
if(inc==0)
while(inc==0);
Lcd8_Command(0x0c);
sec++;
if(sec>=60)
sec=0;
Lcd8_Decimal2(count[cur],sec);
else if(dec==0)
while(dec==0);
Lcd8_Command(0x0c);
sec--;
if(sec==0xff)
sec=59;
Lcd8_Command(0x0c);
Lcd8_Display(0x80," TIME IS ",16);
Lcd8_Display(0xc0," STORED ",16);
Delay(65000);Delay(65000);
dd=dec_hex(date);
mn=dec_hex(month);
yy=dec_hex(year);
hh=dec_hex(hour);
mm=dec_hex(min);
ss=dec_hex(sec);
DS1307_settime(hh,mm,ss);
DS1307_setdate(dd,mn,yy);
Lcd8_Command(0x01);
Delay(65000);
void Lcd8_Init()
Lcd8_Command(0x38); //to select function set
Lcd8_Command(0x06); //entry mode set
Lcd8_Command(0x0c); //display on
Lcd8_Command(0x01); //clear display
void Lcd8_Command(unsigned char com)
Data_Port=com;
Lcd_en=1;
Lcd_rs=Lcd_rw=0;
Delay(125);
Lcd_en=0;
Delay(125);
void Lcd8_Write(unsigned char com,unsigned char lr)
Lcd8_Command(com);
Data_Port=lr; // Data
Lcd_en=Lcd_rs=1;
Lcd_rw=0;
Delay(125);
Lcd_en=0;
Delay(125);
void Lcd8_Display(unsigned char com,const unsigned char *word,unsigned int n)
unsigned char Lcd_i;
for(Lcd_i=0;Lcd_i<n;Lcd_i++)
Lcd8_Write(com+Lcd_i,word[Lcd_i]);
void Lcd8_Decimal2(unsigned char com,unsigned char val)
unsigned int Lcd_hr,Lcd_t,Lcd_o;
Lcd_hr=val%100;
Lcd_t=Lcd_hr/10;
Lcd_o=Lcd_hr%10;
Lcd8_Write(com,Lcd_t+0x30);
Lcd8_Write(com+1,Lcd_o+0x30);
void Lcd8_Decimal3(unsigned char com,unsigned char val)
unsigned int Lcd_h,Lcd_hr,Lcd_t,Lcd_o;
Lcd_h=val/100;
Lcd_hr=val%100;
Lcd_t=Lcd_hr/10;
Lcd_o=Lcd_hr%10;
Lcd8_Write(com,Lcd_h+0x30);
Lcd8_Write(com+1,Lcd_t+0x30);
Lcd8_Write(com+2,Lcd_o+0x30);
void Lcd8_Decimal4(unsigned char com,unsigned int val)
unsigned int Lcd_th,Lcd_thr,Lcd_h,Lcd_hr,Lcd_t,Lcd_o;
val = val%10000;
Lcd_th=val/1000;
Lcd_thr=val%1000;
Lcd_h=Lcd_thr/100;
Lcd_hr=Lcd_thr%100;
Lcd_t=Lcd_hr/10;
Lcd_o=Lcd_hr%10;
Lcd8_Write(com,Lcd_th+0x30);
Lcd8_Write(com+1,Lcd_h+0x30);
Lcd8_Write(com+2,Lcd_t+0x30);
Lcd8_Write(com+3,Lcd_o+0x30);
void Delay(unsigned int del)
while(del--);
void del()
Delay(65000);
Delay(65000);
/*********************************LCD HEADER FILE END*************************************/
/*********************************RTC HEADER FILE START*********************************/
DS1307_get(unsigned char addr)
unsigned char ret;
Rtc_Start();
ret = Rtc_Read(addr);
Rtc_Stop();
return ret;
void DS1307_settime(unsigned char hh, unsigned char mm, unsigned char ss)
Rtc_Start();
Rtc_Write(0x00,ss); /* Write sec on RAM address 00H */
Rtc_Write(0x01,mm); /* Write min on RAM address 01H */
Rtc_Write(0x02,hh); /* Write hour on RAM address 02H */
Rtc_Stop(); /* Stop i2c bus */
void DS1307_setdate(unsigned char dd, unsigned char mm, unsigned char yy)
Rtc_Start();
Rtc_Write(0x04,dd); /* Write date on RAM address 04H */
Rtc_Write(0x05,mm); /* Write month on RAM address 05H */
Rtc_Write(0x06,yy); /* Write year on RAM address 06H */
Send2lcd(unsigned char value)
unsigned char buf1,buf2,buf = 0;
buf1 = value & 0xF0; /* Filter for high byte */
buf1 = (buf1>>4); /* Convert to ascii code */
buf2 = value & 0x0F; /* Filter for low byte */
buf=(buf1*10)+buf2;
return buf;
void Rtc_Init()//lower order 256 bytes of the chip
Rtc_add_wr=0xd0;
Rtc_add_rd=0xd1;
void Rtc_Write(unsigned char zig,unsigned char zag)// program to write to EEPROM
dat_rtc=zig;
temp_rtc=zag;
Rtc_rd_wr_sub();
above:
d_rtc=temp_rtc;
Rtc_Tx();
if (CY==1)goto above;
CY=0;
Rtc_Stop();
Rtc_Read(unsigned char zig)// program to read from EEPROM
dat_rtc=zig;
Rtc_rd_wr_sub();
Rtc_Start();
be:
d_rtc=Rtc_add_rd; // 0xd1 =Rtc_add_rd
Rtc_Tx();
if(CY==1)goto be;
Rtc_Rx();
Rtc_Ack();
CY=0;
Rtc_Stop();
return(datain_rtc);
void Rtc_Start()// must for any operation on EEPROM
sda_rtc=1;
scl_rtc=1;
sda_rtc=0;
scl_rtc=0;
void Rtc_Stop()// this is similar to the START operation whereas this should be performed after the completion of any operation
sda_rtc=0;
scl_rtc=1;
sda_rtc=1;
void Rtc_Tx()// program to send the device address, read/write address,data to be written
signed char i_rtc;
for(i_rtc=7;i_rtc>=0;i_rtc--)// should necessarily be initialised as signed char.
CY=(d_rtc>>i_rtc)&0x01;
sda_rtc=CY;
scl_rtc=1;// clock is essential inorder to write or read
scl_rtc=0;// clk should be alternated
sda_rtc=1;
scl_rtc=1;
CY=sda_rtc;
scl_rtc=0;
void Rtc_Rx()// program read the data from the EEPROM
unsigned char l_rtc;
sda_rtc=1;
for (l_rtc=0;l_rtc<=7;l_rtc++)
scl_rtc=1;
in_rtc=in_rtc<<1;
in_rtc|=sda_rtc;
scl_rtc=0;
datain_rtc=in_rtc;
in_rtc=0;
void Rtc_Ack()// this is to intimate the EEPROM that the read operation is over
sda_rtc=1;
scl_rtc=1;
scl_rtc=0;
void Rtc_rd_wr_sub()// this routine will be used by both the read & write operations to send the device address & the address at which the corresponding action is to be taken
Rtc_Start();
here1:
d_rtc=Rtc_add_wr;// 0xd0 device address is passed
Rtc_Tx();
if(CY==1)goto here1;
again1:
d_rtc=dat_rtc;// the address from which data is to be read/written is to be passed
Rtc_Tx();
if(CY==1)goto again1;
Thanks in advance
#include<reg51.h>
sbit set=P1^2;
sbit mov=P1^3;
sbit inc=P1^4;
sbit dec=P3^7;
sbit ent=P3^6;
void all_disp();
void time_set();
sbit Lcd_rs = P2^0;
sbit Lcd_rw = P2^1;
sbit Lcd_en = P2^2;
sbit sda_rtc =P2^5;
sbit scl_rtc =P2^4;
sbit Lcd_rw = P3^6;
void Lcd8_Init();
void del();
#define SEC 0x00
#define MIN 0x01
#define HOUR 0x02
#define DATE 0x04
#define MONTH 0x05
#define YEAR 0x06
void Rtc_Init();
void Rtc_Start();
void Rtc_Tx();
void Rtc_Rx();
void Rtc_Stop();
void Rtc_Ack();
if(tt>59)
tt+=36;
else if(tt>49)
tt+=30;
else if(tt>39)
tt+=24;
else if(tt>29)
tt+=18;
else if(tt>19)
tt+=12;
else if(tt>9)
tt+=6;
return(tt);
void all_disp()
sec=Send2lcd(sec);
min=Send2lcd(min);
void main()
Lcd8_Init();
Delay(65000);
Delay(65000);
Lcd8_Command(0x01);
Rtc_Init();
while(1)
all_disp();
if(!set)
time_set();
void time_set()
Delay(65000);
Lcd8_Command(0x01);
all_disp();
cur=0;
while(ent)
Lcd8_Command(0x0f);
if(mov==0)
while(!mov);
cur++;
if(cur==6)
cur=0;
if(inc==0)
while(!inc);
date++;
if(date>=32)
date=1;
else if(dec==0)
while(!dec);
date--;
if(date==0xff)
date=31;
if(inc==0)
while(!inc);
month++;
if(month>=13)
month=1;
else if(dec==0)
while(!dec);
month--;
if(month==0xff)
month=12;
if(inc==0)
while(!inc);
year++;
if(year>99)
year=0;
else if(dec==0)
while(!dec);
year--;
if(year==0xff)
year=99;
if(inc==0)
while(inc==0);
hour++;
if(hour>=24)
hour=0;
else if(dec==0)
while(dec==0);
hour--;
if(hour==0)
hour=23;
if(inc==0)
while(inc==0);
min++;
if(min>=60)
min=0;
else if(dec==0)
while(dec==0);
min--;
if(min==0)
min=59;
if(inc==0)
while(inc==0);
Lcd8_Command(0x0c);
sec++;
if(sec>=60)
sec=0;
else if(dec==0)
while(dec==0);
Lcd8_Command(0x0c);
sec--;
if(sec==0xff)
sec=59;
Lcd8_Command(0x0c);
dd=dec_hex(date);
mn=dec_hex(month);
yy=dec_hex(year);
hh=dec_hex(hour);
mm=dec_hex(min);
ss=dec_hex(sec);
Lcd8_Command(0x01);
Delay(65000);
void Lcd8_Init()
Data_Port=com;
Lcd_en=1;
Lcd_rs=Lcd_rw=0;
Delay(125);
Lcd_en=0;
Delay(125);
Lcd8_Command(com);
Lcd_en=Lcd_rs=1;
Lcd_rw=0;
Delay(125);
Lcd_en=0;
Delay(125);
Lcd_hr=val%100;
Lcd_t=Lcd_hr/10;
Lcd_o=Lcd_hr%10;
Lcd_h=val/100;
Lcd_hr=val%100;
Lcd_t=Lcd_hr/10;
Lcd_o=Lcd_hr%10;
val = val%10000;
Lcd_th=val/1000;
Lcd_thr=val%1000;
Lcd_h=Lcd_thr/100;
Lcd_hr=Lcd_thr%100;
Lcd_t=Lcd_hr/10;
Lcd_o=Lcd_hr%10;
while(del--);
void del()
Delay(65000);
Delay(65000);
unsigned char ret;
Rtc_Start();
Rtc_Stop();
return ret;
Rtc_Start();
Rtc_Start();
buf=(buf1*10)+buf2;
return buf;
Rtc_add_wr=0xd0;
Rtc_add_rd=0xd1;
dat_rtc=zig;
temp_rtc=zag;
Rtc_rd_wr_sub();
above:
d_rtc=temp_rtc;
Rtc_Tx();
CY=0;
Rtc_Stop();
dat_rtc=zig;
Rtc_rd_wr_sub();
Rtc_Start();
be:
Rtc_Tx();
if(CY==1)goto be;
Rtc_Rx();
Rtc_Ack();
CY=0;
Rtc_Stop();
return(datain_rtc);
sda_rtc=1;
scl_rtc=1;
sda_rtc=0;
scl_rtc=0;
sda_rtc=0;
scl_rtc=1;
sda_rtc=1;
signed char i_rtc;
sda_rtc=CY;
sda_rtc=1;
scl_rtc=1;
CY=sda_rtc;
scl_rtc=0;
sda_rtc=1;
scl_rtc=1;
in_rtc=in_rtc<<1;
in_rtc|=sda_rtc;
scl_rtc=0;
datain_rtc=in_rtc;
in_rtc=0;
sda_rtc=1;
scl_rtc=1;
scl_rtc=0;
Rtc_Start();
here1:
Rtc_Tx();
again1:
Rtc_Tx();
