GeoAVR
Member level 2
- Joined
- Jun 4, 2014
- Messages
- 48
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 6
- Activity points
- 366
Dear all,
I want to interface a microcontroller with the MAX3798 laser transceiver ic.
The problems are:
1. The MAX3798 has CML (current mode logic) for transmit and receive data but the microcontroller uses 3.3V or 5V voltage logic.
2. The minimum data rate of MAX3798 is 1GBPS but the microcontroller has 150MHz clock.
How can I solve these problems?
Thank you
The problems are:
Thank you
