zedora786
Newbie level 6
i need help in my project.
in my project i will use microcontroller, matlab and electronics lock.
i want to connect a microcontroller with my Laptop, so that when a command goes from MATLAB to the microcontroleer, it should open the electronic lock. how will i do this. e.g when my required result comes from the matlab then it should send a signal to the microcontroller to open the electronic lock.
i want to know that whether it is possible? and if yes then which microcontroller will be used, which command will be used in the matlab to interface the matlab with the microcontroller and then to the electronic lock.
