Interfacing LM35 sensor with PIC 16F877A Problem!!!
imaasac
Newbie level 6
Hi guyz!
I am trying to interface lm35 sensor with PIC microcontroller and light the LED when temperature goes beyond 40 deg Celsius. I am using 16F877a pic and using compiler PICC in C language. I have done simulation on Proteus and got no results. I have write this code, can any body tell me where is the problem in this code. Thanks
#use delay(clock=10000000)
int16 temp, cent;
int16 triptemp, triptempc=40;
void main()
   setup_adc_ports(all_ANALOG);
   setup_adc(ADC_clock_internal);
   set_adc_channel(0);
   TripTemp = ((TripTempC/1023)*500);
   while(1)
      temp=read_adc();
      cent=((temp/1023)*500);
      if(cent>triptemp)
        output_high(53);
      else
      output_low(53);
      delay_ms(100);
ckshivaram
Advanced Member level 5
villingen (Germany) / Bangalore
search in the forum.... you will get it
---------- Post added at 22:04 ---------- Previous post was at 22:01 ----------
you already got the code and already the program for temp measuring and activating buzzer from me and tahmid,......
you expect us to do the project for you..............
already told.. until you learn yourself you will always run for help... dont expect tahmid to answer viva tooo.. he is a busy person
imaasac
Newbie level 6
Dear Thank U for your code... but that code is not of use for my project.... first because i dont understand the code and your code is very lengthy and also extra code is given which is waste of memory.
I thought some one can help me here to learn something.
Tahmid
Silicon Valley, California, USA (from Dhaka, Bangl
I see a few problems. I use mikroC and don't use PICC much, but try with this:
int16 temp, cent;
int16 triptemp, TripTempc=40;
void main()
   TRISA = 0x01;
   TRISD = 0; //You haven't specified buzzer output
   set_adc_channel(0);
   triptemp = (TripTempC*500)/1023; //This should be how it is. First dividing by 1023 makes the result always equal 0
   while(1)
      temp=read_adc();
      cent=(temp*500)/1023; //Same mistake here
      if(cent>triptemp)
        output_high(PIN_D0); //What's 53?, Try with PIN_D0 (I assume this is where buzzer is connected)
      else
      output_low(PIN_D0); //Same here
      delay_ms(100);
Hope this helps.
Tahmid.
