Interfacing DHT11 sensor to microcontroller.
dsk2858
Member level 2
Chennai,India
Hi,:?:
i actually bought a temperature cum humidity sensor(DHT11) which produces digital out put whose working voltage is from 3.5v to 5.5v.
But the MCU which i am using can produce only upto 3.3v from the output port pins.As this voltage can not power up the DHT11 .
could any one please provide me the solution for this.
thanking you in advance.
skogsjanne
Full Member level 3
You run it from 5V and get the 3,3V for the MCU from an LDO regulator.
bigdogguru
Administrator
Southwest, USA
What is the microcontroller you are using in your design? Be specific.
Does it have any 5V tolerant pins/inputs?
BigDog
dsk2858
Member level 2
Chennai,India
i am using RF200PD1 MCU by SYNAPSE,which is a Zigbee based MCU. it does not have any 5V tolerant pins/inputs.
I also attached the electrical characteristics of RF200PD1 MCU and DHT11 sensor.
please suggest me which LDO regulator suites my application.
bigdogguru
Administrator
Southwest, USA
According to your attachment as well as two datasheets I have on the DHT11, the device has a normal operating voltage range of 3v - 5.5v DC, therefore you should be able to power the DHT11 at the same voltage as the RF200PD1 and no level translation/shifting would be necessary.
BigDog
dsk2858
Member level 2
Chennai,India
thanku
when i am connecting the sensor to the RF200PD1 mcu should i add a resister or a capacitor.
bigdogguru
Administrator
Southwest, USA
No, not inline.
However, you will need a pullup resistor on the data line from the DHT11 to the RF200PD1.
The datasheet sheets I have recommend a pullup resistor value of 5KΩ for runs less than 20 meters.
BigDog
