Interfacing Bluetooth USB Dongle with PIC18F4550
saeed_pk
Full Member level 4
Islamabad, Pakistan
pic18f bluetooth
Dear All;
I have a problem in which i have to interface Bluetooth Dongle with my PIC
I want to transmit data serially over bluetooth protocol
here is the scheme
[Seial Data] <----> [PIC18F4550]<-->[Bluetooth Dongle] ~~~~~~~~~~
~~~~~~~~~ [Bluetooth Dongle]<--->PIC18F4550]<-->[Serial Data Out]
I want to replace my serial communication Cable(RS232) Please help me in this regard
Is this possible to make some solution like that
I need the firmware codes to control that Bluetooth Dongle
Information/Specification about bluetooth is also required.
blueroomelectronics
Advanced Member level 5
Toronto, Canada
pic18 bluetooth
You need a serial bluetooth adapter, the USB one won't work with the 18F4550. (they are both USB clients, you need a USB host)
Kripton2035
Western Europe
pic 18f4550 bluetooth
you can do it with pic24f, but not with pic 18 as explained above: pic18 is only usb client
pic 24f can be host and client
warning: not all pic24f can do it...
saeed_pk
Full Member level 4
Islamabad, Pakistan
pic18f4550 bluetooth
It means i can't interface USB Data Traveler(Flash) device to my PIC for data storage as this is a client too.
please advice
Kripton2035
Western Europe
bluetooth pic18f
you can use a pic24f which supports usb host,
or use maxim max3420 which is a spi interface and supports host usb too. it will make a link between your pic18f and your usb client device.
muoinhohn
Full Member level 2
Hanoi
how to make serial bluetooth dongle
I think it is a difficult task if we use microcontroller (like pic24f) for interfacing with USB dongle, because we need implement one USB driver that manufacturer of USB dongle do not give to us.
Muoinhohn
blueroomelectronics
Toronto, Canada
bluetooth dongle usb pic18
Muoinhohn
You nailed it. It's also much more than just a driver, it's also the bluetooth stack.
issaiass
Member level 3
18f4550 usb bluetooth
if your goal is to make bluetooth communications, why you only buy an embedded module?... search in www.a7eng.com, the modules are for dummies... string commands.
felis_CO
Junior Member level 1
18f4550 bluetooth
MAX3420 is peripheral only. The USB host is MAX3421E. I'm developing code for this controller; the USB layer is pretty compact, around 3-5K. I don't have BT driver for it though, only HID atm.
tariqsaeed
Newbie level 6
Dear, saeed_pk I have the same issue with one of my students projects and although I intially agreed with blueroomelectronics but I continued my search.
I came up with this Project by "three Juniors in Cornell University's College of Engineering." at the following link. https://courses.cit.cornell.edu/ee4...ct23/blh36_cdl28_dct23/index.html#codelisting
They achieved the seemingly impossible.
I hope it helps.
Please note that there is a work around to do it the other way around too; using a simple controller to function as a USB device. the link is: http://www.cesko.host.sk/IgorPlugUSB_RS232/IgorPlug-USB%20(AVR)%20RS232_eng.htm
(Please select the entire line above and paste it in your browser for it to work)
El-Master
Newbie level 6
USA
Yeah...a standard serial Bluetooth adapter will make this project much easier. I made a similar setup with this standard Blutooth adapter and its easy to setup, configure and use.
