xinz
Junior Member level 1
74hc14n
I try to connecting 2 board.
the 1st board contain AVR, it's output is ttl signal clock.
the 2nd board, is the receiver of ttl signal, it use 74hc14n chip.
at the input stage of 74hc14n, i put 10k pull up, followed by 10k resistor to input pin of 74hc14n.
it don't work.
is it because I use different power source & ground on each board?
it don't work.
