Naresh10
Newbie level 2
Pls anyone can u tell me wat to do for interfacing 8051 with GSM module, i hav bought AT89S51, i am jus beginner and need to buy GSM module. What are the steps i need to follow for interfacing ?? Anyone pls help me??
First check whether it is a Sim300/Wave form..
i have worked with sim 300.Check whether it is a TTL output or inbuilt max232 output.if it is a TTL output then connect the RX and TX pin to MAX 232 board and connect a DB9 connector to your PC..Insert SIM in GSM Module & Switch on.
Open Hyperterminal and set Baud Rate of 9600.
Type AT .....Press Enter
If you get OK then it is working
Later Type AT+CMGF=1 ......Press enter
You will get OK
To Read a message AT+CMGR=1 ......Press enter........this will read first message if u want another then Type a number
To Send a message AT+CMGS="9966333220" .......... ......Press enter (You type to which mobile number the message has to send)
you will get >
Then Type the message you want to send..
Then Press Ctrl+Z...
After sending it will give OK.
then Disconnect and connect the RX ant TX pin of GSM module to Pin 8 and 9
write the program as i described the above steps.
