Grab a bluetooth-module with a serial port. They are available for like $20 or you can rip it out of an bluetooth access point or similar. You could also have very much luck and use an USB-stick, but you would need to reprogram the firmware at least. Better search for a new module with serial port.
Then you can choose to either implement the full HCI protocol, or do it simpler, by choosing a module firmware which only supports the serial port protocol.
You can then instruct the module to open a connection to the mobile phone. then you usually issue AT-requests, depending on the rfcomm-port you are connecting to.
