Thanks soo much Teja... for your reply
Thanks & Regards
Muthamil
Added after 2 hours 18 minutes:
Could you help me, regarding the possible usage of these input pins...
Digilent 6-pin header -2
EXP expansion connector - 2
30-pin GPIO connector: can be used for System ACE™ Compact Flash daughter card (not included)
Is it possible to connect the add on board using this IO pins.
Actually i am try to sort out the advantage of Spartan-3A DSP 1800A FPGA
Thanks & Regards
Venkat
