integrator using VHDL
V
Member level 3
vhdl integrator
I want to ask how can I write a integrator using VHDL?
how to use "if else" this kind of command to form a integrator?
thanks a lot~
integrator vhdl
Are you looking for simulation only integrator model OR
Digital equivalent synthesizable integrator???
integrator in vhdl
In fact, i need to write a correlation detector, and in between, there are 2 parts, signal multiplcation and integrator.
So, i want to write a integrator first.
thank you so much.
Re: integrator vhdl
I am trying to implement a digital equivalent synthesizable integrator... could somebody help me with this..
Did read about Digital Differential Analyzer... but its confusing.. could somebody help me with this..
Thanks in advance
can you show us the mathematical model your integrator?
Numerical Methods--Euler's Method
this is the procedure as far I know.. and btw I am using euler's forward method of approximation to perform the integration... There was another page which explained this in depth.. but that doesnt seem to be working now..
http://instruct1.cit.cornell.edu/courses/ece576/DDA/index.htm
Please find the attached document to check out what I have done.. Might be if you go through it.. you might understand it better..
  • project01.zip
