maryamohsin
Newbie level 3
hello
i am making a project on xilinx EDK XPS. im using the Create and Import Peripheral to create my own ip. then im integrating an independent vhdl file with it. it is basically a multiplier. my vhdl file has two 16 bit input ports and one 32 bit outputs. i want to send data to my ip from the C application software written in the xps project but i am unable to do so. the idea is to somehow connect my ip ports to s/w accessable registers in the ip, then write/read data to/from the registers. the ports will be assigned the registers in the user_logic module that is autpmatically generated in xps. the actual multiplication will be performed in the vhdl file using ports. i am unable to connect the ports to the registers.
i want to know how to pass values to my ip ports using s/w accessable registers.
mu user_logic file (modified) is
-- user_logic.vhd - entity/architecture pair
-- ** Copyright (c) 1995-2008 Xilinx, Inc. All rights reserved. **
-- ** Xilinx, Inc. **
-- ** XILINX IS PROVIDING THIS DESIGN, CODE, OR INFORMATION "AS IS" **
-- ** AS A COURTESY TO YOU, SOLELY FOR USE IN DEVELOPING PROGRAMS AND **
-- ** SOLUTIONS FOR XILINX DEVICES. BY PROVIDING THIS DESIGN, CODE, **
-- ** OR INFORMATION AS ONE POSSIBLE IMPLEMENTATION OF THIS FEATURE, **
-- ** APPLICATION OR STANDARD, XILINX IS MAKING NO REPRESENTATION **
-- ** THAT THIS IMPLEMENTATION IS FREE FROM ANY CLAIMS OF INFRINGEMENT, **
-- ** AND YOU ARE RESPONSIBLE FOR OBTAINING ANY RIGHTS YOU MAY REQUIRE **
-- ** FOR YOUR IMPLEMENTATION. XILINX EXPRESSLY DISCLAIMS ANY **
-- ** WARRANTY WHATSOEVER WITH RESPECT TO THE ADEQUACY OF THE **
-- ** IMPLEMENTATION, INCLUDING BUT NOT LIMITED TO ANY WARRANTIES OR **
-- ** REPRESENTATIONS THAT THIS IMPLEMENTATION IS FREE FROM CLAIMS OF **
-- ** INFRINGEMENT, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS **
-- ** FOR A PARTICULAR PURPOSE. **
-- Filename: user_logic.vhd
-- Version: 1.00.a
-- Description: User logic.
-- Date: Mon Feb 22 18:25:26 2010 (by Create and Import Peripheral Wizard)
-- VHDL Standard: VHDL'93
-- Naming Conventions:
-- active low signals: "*_n"
-- clock signals: "clk", "clk_div#", "clk_#x"
-- reset signals: "rst", "rst_n"
-- generics: "C_*"
-- user defined types: "*_TYPE"
-- state machine next state: "*_ns"
-- state machine current state: "*_cs"
-- combinatorial signals: "*_com"
-- pipelined or register delay signals: "*_d#"
-- counter signals: "*cnt*"
-- clock enable signals: "*_ce"
-- internal version of output port: "*_i"
-- device pins: "*_pin"
-- ports: "- Names begin with Uppercase"
-- processes: "*_PROCESS"
-- component instantiations: "<ENTITY_>I_<#|FUNC>"
-- DO NOT EDIT BELOW THIS LINE --------------------
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
library proc_common_v2_00_a;
use proc_common_v2_00_a.proc_common_pkg.all;
-- DO NOT EDIT ABOVE THIS LINE --------------------
--USER libraries added here
-- Entity section
-- Definition of Generics:
-- C_SLV_DWIDTH -- Slave interface data bus width
-- C_NUM_REG -- Number of software accessible registers
-- Definition of Ports:
-- Bus2IP_Clk -- Bus to IP clock
-- Bus2IP_Reset -- Bus to IP reset
-- Bus2IP_Data -- Bus to IP data bus
-- Bus2IP_BE -- Bus to IP byte enables
-- Bus2IP_RdCE -- Bus to IP read chip enable
-- Bus2IP_WrCE -- Bus to IP write chip enable
-- IP2Bus_Data -- IP to Bus data bus
-- IP2Bus_RdAck -- IP to Bus read transfer acknowledgement
-- IP2Bus_WrAck -- IP to Bus write transfer acknowledgement
-- IP2Bus_Error -- IP to Bus error response
entity user_logic is
generic
-- ADD USER GENERICS BELOW THIS LINE ---------------
--USER generics added here
-- ADD USER GENERICS ABOVE THIS LINE ---------------
-- DO NOT EDIT BELOW THIS LINE ---------------------
-- Bus protocol parameters, do not add to or delete
C_SLV_DWIDTH : integer := 32;
C_NUM_REG : integer := 3
-- DO NOT EDIT ABOVE THIS LINE ---------------------
port
-- ADD USER PORTS BELOW THIS LINE ------------------
--USER ports added here
-- ADD USER PORTS ABOVE THIS LINE ------------------
-- Bus protocol ports, do not add to or delete
Bus2IP_Clk : in std_logic;
Bus2IP_Reset : in std_logic;
Bus2IP_Data : in std_logic_vector(0 to C_SLV_DWIDTH-1);
Bus2IP_BE : in std_logic_vector(0 to C_SLV_DWIDTH/8-1);
Bus2IP_RdCE : in std_logic_vector(0 to C_NUM_REG-1);
Bus2IP_WrCE : in std_logic_vector(0 to C_NUM_REG-1);
IP2Bus_Data : out std_logic_vector(0 to C_SLV_DWIDTH-1);
IP2Bus_RdAck : out std_logic;
IP2Bus_WrAck : out std_logic;
IP2Bus_Error : out std_logic
attribute SIGIS : string;
attribute SIGIS of Bus2IP_Clk : signal is "CLK";
attribute SIGIS of Bus2IP_Reset : signal is "RST";
end entity user_logic;
-- Architecture section
architecture IMP of user_logic is
--USER signal declarations added here, as needed for user logic
component multiplier
port (
clk: in std_logic;
a: in std_logic_VECTOR(0 to 15);
b: in std_logic_VECTOR(0 to 15);
p: out std_logic_VECTOR(31 downto 0));
end component;
-- Signals for user logic slave model s/w accessible register example
signal slv_reg0 : std_logic_vector(0 to C_SLV_DWIDTH-1);
signal slv_reg1 : std_logic_vector(0 to C_SLV_DWIDTH-1);
signal slv_reg2 : std_logic_vector(0 to C_SLV_DWIDTH-1);
signal slv_reg_write_sel : std_logic_vector(0 to 2);
signal slv_reg_read_sel : std_logic_vector(0 to 2);
signal slv_ip2bus_data : std_logic_vector(0 to C_SLV_DWIDTH-1);
signal slv_read_ack : std_logic;
signal slv_write_ack : std_logic;
begin
--USER logic implementation added here
multiplier_0 : multiplier
port map (
clk => Bus2IP_Clk,
a => slv_reg0(0 to 15),
b => slv_reg1(0 to 15),
p <= slv_reg2);
-- Example code to read/write user logic slave model s/w accessible registers
-- Note:
-- The example code presented here is to show you one way of reading/writing
-- software accessible registers implemented in the user logic slave model.
-- Each bit of the Bus2IP_WrCE/Bus2IP_RdCE signals is configured to correspond
-- to one software accessible register by the top level template. For example,
-- if you have four 32 bit software accessible registers in the user logic,
-- you are basically operating on the following memory mapped registers:
-- Bus2IP_WrCE/Bus2IP_RdCE Memory Mapped Register
-- "1000" C_BASEADDR + 0x0
-- "0100" C_BASEADDR + 0x4
-- "0010" C_BASEADDR + 0x8
-- "0001" C_BASEADDR + 0xC
slv_reg_write_sel <= Bus2IP_WrCE(0 to 2);
slv_reg_read_sel <= Bus2IP_RdCE(0 to 2);
slv_write_ack <= Bus2IP_WrCE(0) or Bus2IP_WrCE(1) or Bus2IP_WrCE(2);
slv_read_ack <= Bus2IP_RdCE(0) or Bus2IP_RdCE(1) or Bus2IP_RdCE(2);
-- implement slave model software accessible register(s)
SLAVE_REG_WRITE_PROC : process( Bus2IP_Clk ) is
begin
if Bus2IP_Clk'event and Bus2IP_Clk = '1' then
if Bus2IP_Reset = '1' then
slv_reg0 <= (others => '0');
slv_reg1 <= (others => '0');
--slv_reg2 <= (others => '0');
else
case slv_reg_write_sel is
when "100" =>
for byte_index in 0 to (C_SLV_DWIDTH/8)-1 loop
if ( Bus2IP_BE(byte_index) = '1' ) then
slv_reg0(byte_index*8 to byte_index*8+7) <= Bus2IP_Data(byte_index*8 to byte_index*8+7);
end if;
end loop;
when "010" =>
slv_reg1(byte_index*8 to byte_index*8+7) <= Bus2IP_Data(byte_index*8 to byte_index*8+7);
end if;
end loop;
-- when "001" =>
-- for byte_index in 0 to (C_SLV_DWIDTH/8)-1 loop
-- if ( Bus2IP_BE(byte_index) = '1' ) then
-- slv_reg2(byte_index*8 to byte_index*8+7) <= Bus2IP_Data(byte_index*8 to byte_index*8+7);
-- end if;
-- end loop;
when others => null;
end case;
end if;
end if;
end process SLAVE_REG_WRITE_PROC;
-- implement slave model software accessible register(s) read mux
SLAVE_REG_READ_PROC : process( slv_reg_read_sel,slv_reg2 ) is
begin
case slv_reg_read_sel is
-- when "100" => slv_ip2bus_data <= slv_reg0;
-- when "010" => slv_ip2bus_data <= slv_reg1;
when "001" => slv_ip2bus_data <= slv_reg2;
when others => slv_ip2bus_data <= (others => '0');
end case;
end process SLAVE_REG_READ_PROC;
-- Example code to drive IP to Bus signals
--IP2Bus_Data <= slv_ip2bus_data when slv_read_ack = '1' else
--(others => '0');
IP2Bus_WrAck <= slv_write_ack;
IP2Bus_RdAck <= slv_read_ack;
IP2Bus_Error <= '0';
end IMP;
and my vhdl file is
library ieee;
entity multiplier is
port(
clk : in std_logic;
a : in std_logic_vector(15 downto 0);
b : in std_logic_vector(15 downto 0);
p : out std_logic_vector(31 downto 0)
end multiplier;
architecture IMP of multiplier is
begin
process (clk)
begin
if (clk'event and clk = '1') then
p <= unsigned(a) * unsigned(b);
end if;
end process;
end IMP;
-- Version: 1.00.a
-- generics: "C_*"
library ieee;
-- Entity section
generic
port
port (
clk: in std_logic;
end component;
begin
port map (
clk => Bus2IP_Clk,
p <= slv_reg2);
-- Note:
begin
else
when "100" =>
end if;
end loop;
when "010" =>
end if;
end loop;
-- when "001" =>
-- end if;
-- end loop;
end case;
end if;
end if;
begin
end case;
--(others => '0');
end IMP;
and my vhdl file is
library ieee;
port(
clk : in std_logic;
end multiplier;
begin
process (clk)
begin
end if;
end process;
end IMP;
