RAVI30
Junior Member level 3
- Joined
- Oct 25, 2013
- Messages
- 27
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Location
- Bangalore
- Activity points
- 230
Hi....
i am need to use integer multiplication in my design both are integers only... but while simulating the multiplication result is coming as zero.......
my design is as folloes
plz help me to solve this problem
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; use ieee.numeric_std.all; architecture arch of bch_syndrome is signal e1:std_logic_vector(15 downto 0); signal b1:std_logic_vector(15 downto 0); signal c1:integer;--unsigned(15 downto 0); signal f1:integer range 0 to 65536; signal d1:integer;--unsigned(31 downto 0); signal syndromesum1:integer; signal i1:integer range 0 to 65535; signal j1:integer range 0 to 32400; begin process(reset,clk,count) variable a1:std_logic_vector(15 downto 0); begin if(clk'event and clk= '1') then if(reset='1')then i1<=0; j1<=32400; b1<=(others=>'0'); c1<=0; d1<=0; a1:=(others=>'0'); e1<=(others=>'0'); syndromesum1<=0; else e1<=(e1(14 downto 0)& DataIn1(j1)); b1<=a1 xor e1; c1<= conv_INTEGER(b1); f1<= alpha_value(i1); d1<=f1*c1; syndromesum1<=syndromesum1+d1; a1:=conv_STD_LOGIC_VECTOR(d1, 16); d1<=0; j1<=j1-1; end if; end if; end process;
