rudie
Junior Member level 3
hello guys,
I want to make a circuit that gets rid of 0.7V on a dc signal. In the attachment you will find a picture of the circuit that i made. In the simulation it works perfect. But if i built it up, it doesn't, It works until the source V1 is 1.3V if it goes below 1.3V (0.6V difference, so 0.6V is the output voltage). The output remains at 0.6V it doesn't go lower. In the schematic you see that i used a Ua741 i replaced that on my board with a LM358 which has a lower voltage swing. But still it doesn't go lower that 0.6V.
The second problem is that the voltage that is produced by the resistor divider of R9 and R10 (the 0.7V that i need), changes if if change V1. How is this possible V1 isn't even in connection with R9 and R10.
I hope that someone can help me
greets rudie
greets rudie
