Sakee Kawsar
Newbie level 1
- Joined
- Aug 25, 2014
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 27
I need help to fix my code. I cannot instantiate it. Its entity has 12 bit input .
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 LIBRARY ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; ENTITY computus IS port(CLK : in bit; year : in unsigned(11 downto 0); April : out bit; day: out unsigned (4 downto 0)); END computus; -- ARCHITECTURE structure OF computus IS component a_div port(CLK, St: in bit; Dbus: in unsigned(15 downto 0); Quotient: out unsigned(15 downto 0); Remainder : out unsigned(15 downto 0); V, Rdy : out bit); end component; signal State : integer range 0 to 6; signal Count : unsigned(3 downto 0); signal Sign, C, Cm2 : bit; signal Sum, Compout : unsigned(15 downto 0); signal Dividend: unsigned(31 downto 0); constant Divisor: std_logic_vector(15 downto 0):= X"13"; alias Acc: unsigned( 15 downto 0) is Dividend(31 downto 12); begin a0:a_div port map (year(0),Compout(0),Divisor(0),Dividend(0)); a1:a_div port map (year(1),Compout(1),Divisor(1),Dividend(1)); a2:a_div port map (year(2),Compout(2),Divisor(2),Dividend(2)); a3: a_div port map (year(3),Compout(3),Divisor(3),Dividend(3)); a4:a_div port map (year(4),Compout(4),Divisor(4),Dividend(4)); a5:a_div port map (year(5),Compout(5),Divisor(5),Dividend(5)); a6: a_div port map (year(6),Compout(6),Divisor(6),Dividend(6)); a7:a_div port map(year(7),Compout(7),Divisor(7),Dividend(7)); a8:a_div port map(year(8),Compout(8), Divisor(8),Dividend(8)); a9:a_div port map(year(9),Compout(9),Divisor(9),Dividend(9)); a10:a_div port map(year(10),Compout(10),Divisor(10),Dividend(10)); a11:a_div port map(year(11),Compout(11),Divisor(11),Dividend(11)); process(CLK) begin if CLK'event and CLK = '1'then case State is when 0 => if St = '1' then Acc <= Dbus; Sign <= Dbus(15); State <= 1; V <= '0'; Count <= "0000"; end if; when 1 => Dividend (15 downto 0) <= Dbus; State <= 2; when 2 => Divisor <= Dbus; if Sign = '1' then dividend <= not dividend + 1; end if; State <= 3; when 3 => Dividend <= Dividend(30 downto 0) & '0'; Count <= Count + 1; State <= 4; when 4 => if C = '1' then v <= '1'; State <= 0; else Dividend <= Dividend(30 downto 0) & '0'; Count <= Count + 1; State <= 5; end if; when 5 => if C = '1' then ACC <= Sum; dividend(0) <= '1'; else Dividend <= Dividend(30 downto 0) & '0'; if Count = 15 then State <= 6; end if; Count <= Count + 1; end if; when 6 => State <= 0; if C = '1' then Acc <= Sum; dividend(0) <= '1'; State <=6; elsif (Sign xor Divisor(15)) = '1' then Dividend <= not Dividend + 1; end if; end case; end if; end process; Cm2 <= not divisor; compout <= divisor when Cm2 = '0' else not divisor; Sum <= Acc + compout + unsigned'(0=>Cm2); C <= not Sum(15); Quotient <= Dividend(15 downto 0); Remainder <= Dividend(31 downto 16); Rdy <= '1' when State = 0 else '0'; end structure;
