InstallScape (IC610 & MMSIM61) on fedora8
venkatreddydec30
Newbie level 5
Hi
Problem 1
Extracting InstallScape version for platform lnx86 in / opt / InstallScape
./SETUP.SH: line 814: uncompress: command not found . / SETUP.SH: line 814: uncompress: command not found
Starting up InstallScape in GUI mode Starting up InstallScape in GUI mode
DISPLAY environment variable is set to :0.0 DISPLAY environment variable is set to: 0.0
If you do not see the InstallScape console If you do not see the InstallScape console
window or the it seems to be hanging then kill this window or the it seems to be hanging then kill this
process.
Set your DISPLAY environment variable to a proper Set your DISPLAY environment variable to a proper
value and manually start InstallScape by typing: value and manually start InstallScape by typing:
/opt/InstallScape/iscape/bin/iscape.sh /opt/cadence/IC610_lnx86.Base/CDROM1 / opt / InstallScape / iscape / bin / iscape.sh / opt/cadence/IC610_lnx86.Base/CDROM1
:::/opt/IC610 ::: / opt/IC610
solution 1)
ln-s / bin / gunzip / bin / uncompress
Problem 2)
process.
/eda/cadence/installscape/iscape/bin/iscape.sh /eda/cadence/IC610_lnx86.Base/CDROM1:::/eda/cadence/install / eda / cadence / installscape / iscape / bin / iscape.sh / eda/cadence/IC610_lnx86.Base/CDROM1::: / eda / cadence / install
Initializing InstallScape using JVM at /eda/cadence/installscape/iscape/runtime/LNX86/bin/java. This might take some time... Initializing InstallScape using JVM at / eda/cadence/installscape/iscape/runtime/LNX86/bin/java. This might take some time ...
Exception in thread "main" java.lang.UnsatisfiedLinkError: /eda/cadence/installscape/iscape/runtime/LNX86/lib/i386/libawt.so: libXp.so.6: cannot open shared object file: No such file or directory Exception in thread "main" java.lang.UnsatisfiedLinkError: / eda/cadence/installscape/iscape/runtime/LNX86/lib/i386/libawt.so: libXp.so.6: cannot open shared object file: No such file or directory
at java.lang.ClassLoader$NativeLibrary.load(Native Method) at java.lang.ClassLoader $ NativeLibrary.load (Native Method)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1586) at java.lang.ClassLoader.loadLibrary0 (ClassLoader.java: 1586)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1503) at java.lang.ClassLoader.loadLibrary (ClassLoader.java: 1503)
at java.lang.Runtime.loadLibrary0(Runtime.java:788) at java.lang.Runtime.loadLibrary0 (Runtime.java: 788)
at java.lang.System.loadLibrary(System.java:834) at java.lang.System.loadLibrary (System.java: 834)
at sun.security.action.LoadLibraryAction.run(LoadLibraryAction.java:50) at sun.security.action.LoadLibraryAction.run (LoadLibraryAction.java: 50)
at java.security.AccessController.doPrivileged(Native Method) at java.security.AccessController.doPrivileged (Native Method)
at java.awt.Toolkit.loadLibraries(Toolkit.java:1437) at java.awt.Toolkit.loadLibraries (Toolkit.java: 1437)
at java.awt.Toolkit.<clinit>(Toolkit.java:1458) at java.awt.Toolkit. <clinit> (Toolkit.java: 1458)
at com.khanpur.installer.gui.InstallerUI.main(InstallerUI.java:70) at com.khanpur.installer.gui.InstallerUI.main (InstallerUI.java: 70)
Can someone help me solve this
alletoni
Newbie level 3
to solve problem 2 try this
su -c 'yum install libXp'
gemini42
Newbie level 3
Hi when I tried to install I had the same problem. I changed my OS to Slackware 12.1. It is amazing distruibution and I had no problem. Everything worked fine. Just a couple of lib files need to be updated but it works well...
