if you are a begineer, i suggest that you install you linux in vmware,then it will be easy to search materials in internet and you can uninstall this linux and install another version linux.
but there is a problem that cadence ic demand that your video card set to 24bit depth color.In a pure linux, it is easy for most of the video card. but in vmware you should download a vmware driver from the vmware home site and install it,the you can set the 24bit depth.I have use this method ,and the IC work correctly.
