Install IC5141 on suse 10.2 help ?
RF_TU
Newbie level 3
Newbie level 3
Hello,
can somebody guide me to install IC5141 on Suse 10.2? I am initial!
I launched ./SETUP.SH it makes me this error:
Creating directory /Cadence
\c
Setting up softload for lnx86 in /Cadence
\c
The following tar errors were detected:
\c
/bin/tar: -b1: ne peut être retrouvé dans l'archive.
/bin/tar: Statut d'erreur reporté d'erreurs précédentes.
Could not set up SoftLoad in /Cadence\c
You must have write permissions to install directory \c
and all its subdirectories
and atleast 10 MB available disk \c
space in install directory.
\c
Thank you
yep try to install an older version like 1.13
I've met the same problem and solved it described below.
1. Rename original tar (/bin/tar) to tar2 for example (/bin/tar2)
2. make a script with name /bin/tar with the following source:
============== script starts here =====================
#!/bin/bash
i=""
while [ $# -gt 1 ]; do
if [ "$1" != "-b1" ]; then
i="$i $1"
fi
shift
done
i="$i $1"
fi
/bin/tar2 $i
================ script ends here ===================
This script analyzes all parameters passed to tar and excludes "-b1" parameter (this parameter is not supported in newer versions of tar and this parameter is the reason of error)
