ansonyeap
Member level 2
HI All,
Can someone teach me on how to simulate and judge the input voltage range of an op-amp for which the op-amp is working properly?.
my method is as below:
1. Connect the op-amp in buffer configuration
2. connect a DC source at the positive terminal of op-amp
3. Sweep the DC source from 0V to Op-amp power supply
4. Take the different between the output of the op-amp and the DC source
5. based of the acceptable deviation of the output(i.e 1mV) from input, the input range is determined.
Is my method correct? please help me on this. thank you
