input transition time and output load capacitace in .lib
Mahendra Kumar Jatav
Newbie level 6
Hi,all
what is procedure to calculate the input transition time and output load capacitances for a pin of a standard cell in .lib file.so we can use this for calculating the power value from power_lut_template.because we know that if we want to match the internal power given by the tool and we calculate manually using .lib file then we must know about the two parameters. or anybody also tell me how the power is dissipated in a standard cell using .lib file with calculation using power luk table.
