Input Duty Cycle in XILINX Virtex5 FPGA
shyam4908
Newbie level 6
Can i convert the input clock with duty cycle 40/60 to nearly 50/50 duty cycle using DCM (or) PLL in xilinx Vitertex5 FPGA
Regards
Shyam
Well, you can set the DCM's DUTY_CYCLE_CORRECTION attribute to true.
Refer to Virtex-5's user guide ug190 and search 'duty cycle correction' for more details.
    shyam4908
Thanks philoman...
But the duty cycle correction works only for clk1x..i.e. clk0, clk90, clk270...but for clkfx it varies depend on M/D....i do not want to use one more dcm to generate clkfx using the output of first dcm..i want to know the tolerance for M/D values..
Hi shyam,
U can use PLL's "CLKOUT[0:5]_DUTY_CYCLE" attribute to get required (50%) duty cycle.
