An integrator is built with an opamp and a feedback capacitor acossing the output node and negative input node of the opamp. The input current charges the negative input node, and the negative input node will manitain virtual ground, and the output voltage has a ramp signal.
Where is the input current going? The input current can not across the feedback capacitor, and the input gate of the transistor is a high impedance. Thanks.
The input current is required to have zero average. Please notice that an integrator must be either equipped with a reset switch or operated with external negative feedback, otherwise it runs into saturation.
Review real world integrator applications for clarification.
It's true that the capacitor needs to charge through a sensible value of impedance. If it sees near-infinite ohms in either direction then it isn't workable. Possibly the incoming signal comes through a very high resistance (or unknown resistance). In that case a proper op amp schematic needs to include a component (example, resistor) which creates a workable RC network with the capacitor.
Assume the input current is dc current, it can not go through the feedback capacitor as I1, and it can not go into the negative input node of the opamp ( the gate of transistor), then where it goes? Thank you.
Understand that AC current is DC current until it switches direction. 50hz AC is DC for 10ms periods.
So a cap is perfectly happy passing DC current...until its voltage as described by the equation in post #5 causes circuit saturation or cap failure. Hence in the long run caps can only supply AC.
Why not? Current aka charges are flowing to one of the plates of the capacitor, and the op-amp drains charges (of the same polarity) from the other plate, resulting in a rising potential difference between the two plates (which is equal to the integral of current/capacitor)
Why node Vx ( negative input node of the integator) does not change when the current charges Vx node, because it is is a low impedance node?
For an integrator, the input impedance is 1/(SC)/A. For example, if A=10000, then the input impedance of the integrator is still infinite for dc frequency?
It does not change only if your gain is infinite. If your gain is finite, it does change.
Sure, the feedback loop of force negative and positive node of the opamp to be equal.
Input current charges the negative node of the opamp, making it has a voltage rise, then the feedback loop sinks the output current leading to the voltage on the other plate of the capacitor ( the output of opamp ) to drop. This voltage drop has a bootstrap effective that making the negative input node to drop until it is equal to positive node voltage. Does it operate like this way? Thank you.
