input common mode range
aru_vlsi
hi
can anyone clear the idea of input common mode range in differential amplifier
you can run the simulation under different common mode voltage. and get the THD results.
the two voltage get -3dB worse THD is the common mode range.
Hi
Do u mean do transient simulation with different common mode voltage?
And why THD is -3dB worse beyong common mode range?
I think THD is mostly related to the amplitude of the signal.
Could we just change the bias voltage of the differential amplifier and check its operating point?
Thanks!
Hi
Renwl's way is very good but difficult and time consuming.
there is another way,
Plot output dc voltage vs. input dc voltage.
(sweep input dc voltage)
note that you must plot single ended output .
input range that cause linear curve, is ICMR.
(it is if you don't have swing in input)
regards
configure your op-amp as unity gain buffer. Now, sweep your DC input, and plot output vs input.The linear region in your output with gradient 1 is your ICMR.
dc sweep of opamp, find the linear range.
