I want to make a circuit that will produce 5V when the input is 5V and produce -5V whent he input is 0V. Does such circuit exist? I have tried several ways, but none of them worked. So if there is any suggestion, please post it. Thanks
Thank you for the reply. The circuit works. I can see that when Vin is 0V, the circuit functions as an inverting amplifier. However, I dont get how does the circuit work when it's Vin is 5V. Please explain it to me, thank you. What I really dont get it, why is R/2 resistor necessary?
when Vin=5V then due to virtual ground the other input's voltage is also 5V and hence no current flows and hence the output voltage is 5V.
as for the R/2... it is to make the input impedance of both the inputs equal.... those two R in the other input can be considered as voltage dividers and hence their impedance is R/2.
