toninlg
port vhdl
I would like to use in VHDL an inout pin with a bidir port, but that doesn't work. There is always logic contention when I simulate it with Quartus.
I would like to send a data to the block if "write" is enabled and read it back if "read" is enable. How could I make it whit the bidir port? The only way I've found is to use an inout pin connected to the block by to way : as an input port and output port.
Thanks a lot.
Thanks a lot.
