Information on floating point ALU architectures
elecs_gene
Member level 2
Member level 2
hi guys
can u give some information on floating point ALU architectures??anything in relevance to floating point ALU would help..
with regards
FLOATING POINT ALU
Before starting with architecture, you should checkout IEEE 754 spec on floating point computation. **broken link removed**
I guess a freecode is available on opencores
Re: FLOATING POINT ALU
hi,
if you want to do fpu, decide which type you want, risc/cisc. if you want to risc, then you just focus on floating point add/sub/mul/divide, or maybe reciporcal or squar root.
but if you want cisc just like 80387, you have to learn more , for example , sin, cos, tan, arc tan, etc.
I think floating point arithmetic is not easy , you can check IEEE paper , there are hundreds on it.
best regards
hi linuxluo,
i think i want to design a risc floating point architecture..now my question is how to go about framing the architecture??now that addition , subtraction , multiplication , division , square root are the operations that i want to perform..should my next type be choosing the type of adder & multiplier??
with regards
