Information about slack in clocks
smith_kang
Member level 5
information about SLACK
hi
i want to know about slack in case of clock.when we synthesise the circuit it gives negative slack and shows constraints not met.
it this means that negative slack is not good for design and we should have positive slack or something else.
plz clearify this.if i'm wrong then correct me
regards
Re: information about SLACK
sure -ve slack is NOT good, basically slack tells u the timing or frequency margin u have, -ve slack means your design doesnt meet the timing requirments u specify, either lower the operating frequency or change your design.
thanks
sawaak
SLACK: Difference between required value of timing parameter and actual value. A
negative slack means that there is a timing violation. A positive slack means that the constraint for the timing parameter is satisfied.
See the attached document.. it gives u a basic introduction to Timing analysis..
/File is deleted. Better use link insted of file:
(klug)/
