Information about parity bits
malaylah
Junior Member level 1
Can anyone tell me how to find extrinsic information with regards to parity bits.I mean how to find extrinsic information of parity bits and information bits?
thanks.
pdf program matlab turbo equalizer
Recommend a good book
Turbo Codes: Principles and Applications
by Branka Vucetic, Jinhong Yuan, Jinhong Yuan
And also, you can google "Turbo code" there are thousands of papers about Turbo codes in the last decade.
turbo equalizer books
You can reference the document "Fundamentals of Turbo Codes" byBernard Sklar. In this paper, there shows an example for the extrinsic information based on the parity bits and the information bit.
turbo codes principles + books
I think this dissertation is the best to understand the subject of Turbo Codes.
turbo codec simulink
I believe that many signal processing books (just search signal processing) would be able to assist you as well.
turbo codes in simulink
Is this book available in soft-copy? If yes, and anybody knows it, pl. post links to it.
about turbocodes
do any one has a MATLAB code implementing turbo equalizer.
Thanks
jinhong yuan
All,
How to implement Turbo code on TI DSP?
Thanks
turbo extrinsic
hi,
i guess the TI L1 layer library has Turbo Decoder implementation for WimaX duo-binary PCCC.
books on turbo code
Hi tatahd,
You may implement Turbo Codes using TMS320C6713 DSK. If you have the simulink model of Turbo Codes I can check them using my DSK.
BR
Ahmed
turbo and matlab simulink
Do you have the C6713 DSK ?
fundamentals of turbo codes
yes, we have it at my university's labolatory and also C6416 DSK.
Please give me advice and thank you so much.
rgds,
tatahd
turbo code simulink matlab
Check this link; it contains a very useful information for you.
BR
papers turbo coding 2008
Thank you so much. I'll try it.
rgds,
tatahd
mathworks turbo code
In which university are you in?
