Info about PLD programming
Help
Advanced Member level 2
Hai.....
Have any teach me????
I have uPSD323X/16f877 uchip, how should i start my PLD, do you know where can get more information about PLD (eg: how to use C language to program it, how to start desgin the simple Combinational&Sequential logic to design something.... like light-up 10LED by sequent or simple design Run-Light).
I hope you can help me..... pls help me!!!
Thank You
plds pdf
if you are using PLD not FPGA,i think you can use Jtag to programme your pld,and not necessary to cfg it with CPU.
for FPGA u can use software to programme
Added after 10 minutes:
gal22v10 jtag
Salam,
The best language to program PLDs is vhdl.
But if you want to use small pld like popular GAL22V10 PLD , you can use APEL as a language.
Search the net using the keywords "APEL" "PLD" "TUTORIAL" ... etc
Read also
to know the plds categories.
Read also
"PLD programming using VHDL
"Digital Design with CPLD Applications and VHDL"
Bye
www.st.com/stonline
Hi !
uPSD323X , from ST, are fast 8051 derivatives with PLD inside.
-The µC part can be programmed with recent C compilers like Keil or Raisonance...
-The PLD part can be programmed with a special IDE using Abel language
-A JTAG link is used to 'flash' and debug the chip.
You can find usefull informations (codes sample, Applications...) here :
https://www.st.com/stonline/products/families/memories/psm/upsd_idx.htm
https://www.st.com/stonline/books/ascii/docs/8970.htm
https://www.st.com/stonline/books/pdf/docs/10392.pdf
Regards
using abel pld
sc/mp said:
Hi !
-The µC part can be programmed with recent C compilers like ke*il or Raisonance...
h**p://www.st.com/stonline/products/families/memories/psm/upsd_idx.htm
h**p://www.st.com/stonline/books/ascii/docs/8970.htm
h**p://www.st.com/stonline/books/pdf/docs/10392.pdf
h**p://www.raisonance.com/download/index.php
Regards
Hai....
Can you share more information about uC (uPSD323) C compiler, where can get this compiller and how to write in embadded C language....
Thank for you infrmation...
TQ....
Added after 30 minutes:
SphinX said:
Salam,
Read also
h**p://www.circuitcellar.com/library/ropes/1199/c119lrpdf.pdf
Read also
h**p:// "PLD programming using VHDL
h**p:// "Digital Design with CPLD Applications and VHDL"
Bye
Hai.... SphinX,
Thanks.... for your good information, i will go tool the all the information.
I have one question... izit PLD difficult to learn need to take spend some time?? If i find out something that i not understand can i find you directly... through yahoo- mail, Hotmail, Massenger and so on???
Rrgd.
